HP Pavilion a705w PC Desktop
Problem for HP Pavilion a705w PC Desktop
My screen below the taskbar keeps on flickering
By nvashum on Oct 17, 2009
I'm using HP pvilion dv4 series with windows vista sp1 and my screen below the taskbar keeps on flickering..Pliz help .......Is it a hardware or software problem?
Best Solution
posted on Oct 17, 2009
Very Helpful)
JomasTech
Rank: Guru
Rating: 87%, 28 votes
that sounds like a either a monitor issue or video card issue. in most cases, if it is a video card, you wouldn't see the image on the screen. I would try the monitor, if you had it for quite a while, it is possible that the monitor is going bad.
I know it is not software problem.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
mbase213
Rank: Guru  HP Expert
Rating: 91%, 224 votes
Hi nvashum,
Here's what you need to do. First just to see a little more of this flickering, right click on the MS symbol or start button, then click on properties. When the window pops up, go to task-bar and click on the button that says auto-hide task bar, then click ok. Once you've done this, it will shrink the task bar down below so you can see if the flickering happens to be some program or it's still along the bottom of the screen. If that shows you nothing, then you can reset it back if you'd like. OH! to get the task bar to pop up again, just move your cursor down to the bottom of the screen and it will pop up for you.
Now, if you find nothing unusual or obvious with that first attempt, the next step would be to find a friend with a monitor that you can hook your computer up to. (P.S. Take your monitor with you as well.)
Turn it on and see if you get the same results. My bet is no, but who knows! Then take your monitor and hook it up to your friends computer to see what results you get. If it does flicker then guess what? It's your monitor for sure.
Now, if it doesn't flicker, then it still could be your video card or on board adapter. Most people don't have extra video cards lying around, so, what you do is go HERE and get some direct advice about the monitor and video card. Plus you can also see if it's still under warranty. Most of the time, these things are as simple as adjusting the settings on the monitor. But they built it, they would be the best ones to manage the hardware issue.
The only other thing I would recommend is to download the driver for it to make sure that it's current. HERE.
Hopefully one of these suggestions will fix your flicker.
Good Luck
Mark
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion a705w PC Desktop
Questions and Unsolved Problems for HP Pavilion a705w PC Desktop
Do you recommend HP Pavilion a705w PC Desktop?
Answer
Answer
wireless internet adapter for a gateway desktop gm5472 which one will it
Answer
I need the user manual or installation manual for Accton EtherHub - 8e having Model No EH2039
Answer
olicard 100 su linux xandros installato su asus eeepc
Answer
where is the wireless radio button on an old HP Pavillion 8705? I just installed a usb wireless... (More)
Answer
I have owned the Hp Pavilion A808 for many years, with an Acer AL1711 monitor. Last night I rebooted... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
