Computer turns on, but there is no display on monitor.
My monitor stays completely black when I turn on the computer. I switched out the monitor with my other monitor (which works perfectly on my other computer) and had the same problem--black screen. Is the video card bad? I believe the video is built-in. Can I buy a video card and put it in one of the two open PCI slots?
i turned my computer off one night before bed as usual, the next morning when i turned it back on, everything came on, but my moniter's orange light never turned green, So i hooked the minitor to my other computer and it worked perfectly, So i bought a G-force MX 4000 vidio card and installed it in my AGPro port and I still dont get nothing, And i just had a new mother board put in my computer not even 3 weeks ago by a service tech,could you please help me solve this problem? I have a 15 inch. flat screen made by Magnavox, And my computer is a e Machine T3410.
  • annemarieuvf Aug 30, 2008
    turn on my pc everything goes on except the monitor it goes from side saying no signal
  • kielerman May 11, 2010
    i have the same problem but how can u go to BIOS if there is no display...the led light on the monitor is yellow...
I fear the problem is with the motherboard. I have came across many boards (same model) iwth same problem,. tech support a bios update will solve the problem.
Posted on Jun 23, 2008
  • 1,894 Answers
My goodness.. you have spent a lot in your computer i think.. i dont think changing mother board and installing a new vedio card will solve this problem.
as u have said that u have installed a new card make sure that you are giving the connections of your monitor to the gforce card and not to the mother board again.
if connection for monitor is going for gforce properly your RAM is the problem. as per your configuration its single 512mb ram. i would advice you to go and get another DDR RAM(same 512 prefrably) from any of your friend and put it in you mother board in by removing the normal RAM you had.
this will work for sure i think.
if this is not working dont rate me in-approtiate. i just triend my best. sorry and tahnks.. good luck
Posted on Dec 28, 2007
Go to the BIOS in Advanced - Chipset
Change the Graphic Adapter Priority setting.
Posted on Aug 02, 2008
I have a 19" cmv
How old is it? If it still under warranty get it repaired, it sounds like the switch is gone or the energy saving s/w inside is bad and is not detecting when/when not to turn the display on/off.
May 22, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
When monitor is turned on, it flickers 3 times and then goes blank
Does the computer stay on or switch off?
If the computer stays on and the monitor completely switches off then it's a monitor power problem.
Make sure all connections are securely connected.
If the computer also completely switches off then it's more likely to be a computer problem.
If it's a monitor problem then the monitor will have to go to a monitor repair shop.
If the box does switch off then let us know to continue to troubleshoot.
Aug 18, 2009 | Gateway Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
No pic on screen
Double check all of your connections. It appears the video cable is not plugged in completely. Try another monitor if possible to see if the computer is actually outputting video.
Jan 03, 2009 | Dell Computers & Internet
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
The builtin video card is probably bad. Yes, you can get a PCI video card.
Dec 28, 2007 | Dell Dimension 2300 PC Desktop
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
1,355 people viewed this question
David Payne
David Payne
