Infinity 475A Car Audio Amplifier
Problem for Infinity 475A Car Audio Amplifier
I just bought a 98 concorde lxi and no sound
By georgouseyes on Oct 17, 2009
i just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Solution #1
posted on Oct 17, 2009
Not Rated)
etirbynnor
Rank: Guru  Car Audio & Electronics  Expert
Rating: 94%, 269 votes
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Infinity 475A Car Audio
Questions and Unsolved Problems for Infinity 475A Car Audio
Do you recommend Infinity 475A Car Audio Amplifier?
Answer
Answer
i was driving down the road and the adio just shut off on my kvt911dvd. no noises or electrical... (More)
Answer
i cant figure out my amp wire color code
Answer
what are the specs on amp model la2259 ..no power from amp and wanted to check resistance
Answer
do not change 1 to 2 velocity in manual shift or automatic D1
Answer
i try to fix amp INFINITY REF475 .PWM on TL494CN is not start . TL494CN I replaced - no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifier Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
