Coleman Sport 1850 Generator
Problem for Coleman Sport 1850 Generator
Mine will run for 10 to 15 mins then shuts down
By ri_payne on Oct 17, 2009
mine will run for 10 to 15 mins then shuts down like it is out of fuel, also when starting i need to play with the choke to run lever to keep it running . it will run best in about the middle setting and then like i say for about 10 15 mins.
Best Solution
posted on Oct 17, 2009
Helpful)
Smooth_Gecko
Rank: Wiz
Rating: 82%, 171 votes
Sounds to me like you have some water in the carby. To check this, loosen the little screw at the bottom of the carby bowl and catch what comes out in a cupped hand. ( you may need to put it on bricks to do this).
If you do have a globule of water running around in the petrol you catch, draining it here for a few seconds with the fuel tap on may be enough to fix it. I would always check the water trap on the bottom of the fuel tap at the same time though.
If this only works for a little while, you may need to remove the fuel tank and drain & dry it with a rag and stick.
Having said all that, I have had similar symptoms
to what you describe, caused by a spark plug, so that is another quick and easy thing to try.
Hope this is of some help.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Coleman Sport 1850 Generator
Questions and Unsolved Problems for Coleman Sport 1850 Generator
Do you recommend Coleman Sport 1850 Generator?
Answer
Answer
Engine is running, but not generating. All circuit breakers have been reset just to make sure they... (More)
Answer
Generator ran fine Friday evening but when I cranked it Saturday evening it ran from 10:00pm to... (More)
Answer
I broke the fuel petcock off - is it available?
Answer
need to know what type oil and oil amount to service a coleman 1850 generator. I lost my manual. ... (More)
Answer
I have an older model 1850 + Sport. Last year I attempted to use it on my small travel trailer and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Power Generator Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
