Question about Hitachi 32UDX10S 32" TV
Long power up time, wavy "static" lines, and red/orange problems
Takes several minutes to come on after power button is pressed. Intermittent discoloration red/greens across middle half. It varies according to picture content. Cartoons and large solid red/oranges (AT&T commercials) across screen cause the most problems. Wavy lines that get better/worse/change when cable is moved behind TV set.
It's a hand-me-down set, and I could even cope with the long warm-up, but the colors and static lines are kind of bothersome.
  • anneli000 Dec 30, 2007
    The cables and connectors are firm. I think it could be a loose connection inside the set.
  • Anonymous Jun 13, 2008
    Hi, I have the same proble with my Phillips hand-me-down TV. It takes a long time 'warming up' with static for about 2 minutes before picture. Picture occasionally stripy and distorted, particularly when blocks of light colors/white are on screen. Constant stripy band across top. Any help would be great. I'm assuming the problem is within the set as external connections seem OK.
  • 3 Answers
Part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Posted on Dec 28, 2007
My tv does not turn on without static and lines and takes up to five minutes turning on and off on its own
Unfortunately It Sounds Like You Have One Of Two Things Going On.The First Is a Defective T-Con( Timer Control Board ), Which Is An Easy Fix..The Second Is an Intermittent Display Panel, Which Is A Common & Costly Problem..
Sep 08, 2014 | Samsung LN-S4692D 46 in. LCD HDTV
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
I havy my ASUS K40IN,,my problem is about powering it up,,i'm having trouble of opening up ,i always press the power button very hard,but it takes me time before opening,sometimes when lucky its e
It is possible you have a intermittent power on/off button that is not working properly, remove main battery to see if that will help, if not! unplug power supply from laptop and remove main battery, next press and hold power for 2 minutes to get rid of any residual voltage, now put everything back together and power up.
May 06, 2012 | ASUS K40IN Notebook
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Philips 28DW9625 - has an intermittent fault where it will turn itself off - like it is going into standby - but the red light flashes and I have to switch off, wait a few minutes, then switch on again....
philips has a problem with bad electrolytic caps in power supply-you can eithor replace the swollen caps in the power supply-pretty easy if you use a solder iron.if not go to shopjimmys.com enter model number-scroll down til you find power supply--after it arrives plug in new one
Sep 11, 2009 | Televison & Video
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
PS3 Freezes On The Wavy Lines
I had the same problem.
Whilst the machine is turned on, plug in the usb to the wireless controller and the PS3 should detect it and ask you to press the ps button (center of controller). Do this and you should get a menu, select RESTORE FACTORY SETTINGS, and you will have to input time, date etc but it does get machine working again - previous data is lost and you may need to keep trying as machine took several attempts to detect wireless controller - just persevere!!! I tried pressing buttons etc, switching off but nothing else worked for me ... Hope this helps
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
Hitachi 32UDX10S 32" TV Logo
149 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
