Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
I have a DWL-2100 AP. I cannot get it to reset to the factory defaults nor can I access the last know LAN IP settings. Is there a "secret code" of button push and disconnects that will really do a reset?
Thanks
  • rrcomp Jan 02, 2008
    I tried this. I've held reset for 15 sec, 30 sec, 60sec. No dice. Logging to the IP of 192.168.0.50 just won't work. Any other ideas?
  • 4 Answers
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Posted on May 10, 2009
  • 55 Answers
If you look at the back of your access point you should see a reset button. Hold that in for about 30 seconds and then log back into it. The IP address should be 192.168.0.50 I hope this solves your problem
Posted on Dec 28, 2007
I have reset the dlink 2100 ap, but now the IP shown on the bar (wireless connection) is 192.168.1.3 and is not possible to enter into the access point with the default IP and config it...any help?
Posted on Jul 25, 2010
Reset, hold for 10/15 secs, do it again 3 times total. Then it works.
Posted on Feb 27, 2008
Hello when i turn on my access point d-link dwl 2100 ap i couldn't access to it by the ip i reset it several times but nothing changes even by the default ip of it 192.168.0.50 so plz help me
In order to get to the web server, you plug an ethernet cable between your computer and the AP. Then, did you miss the instructions that you have to be in the same subnet? Right click on your LAN card (Network) Properties TCP/IP Properties and set the address to something temporary like use 192.168.0.5 or anything but 1 or 50 and the subnet mask to 255.255.255.0
Now when you open up IE, just key in 192.168.0.50 and it will bring up the login box.
Carl
Apr 14, 2011 | Computers & Internet
I change The IP to 192.168.1.102. and if I connect
after reset the wireless device you can connect only through 192.168.1.1 or 192.168.0.1 IP address.
Mar 02, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Dwl-2100ap will not update firmware
1) Reset do default the device (rear reset button)
2) Set your PC a IP like 192.168.0.xxx (defaul IP address for DWL-2100 AP is 192.168.0.50)
3) Connecto via browser to 192.168.0.50, defaul login
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and selectInternet Protocol (TCP/IP), click properties, click set followingIP address:
IP: 192.168.0.1
If this information can help you, please rate me ;)
Aug 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
Jul 18, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Here are the steps to reset the access point from D-Link's website:
Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
http://support.dlink.com/products/view.asp?productid=DWL-2100AP
Mar 15, 2009 | D-Link Computers & Internet
DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
Feb 13, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
After resetting the Access Point i cannot login to admin account
You need to reset the AP to factory default (keep the reset button pressed while powering up the unit).
Nov 15, 2008 | D-Link AirSpot DSA-3200 (F56772) Firewall
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
28,403 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
