Question about Linksys Wireless-G WRT54G Router
Linksis wireless computer setup for WRT54G model
Cannot remember my pass word
  • 1 more comment
  • Glenn Killebrew
    Glenn Killebrew Dec 28, 2007
    Cannot remember my password to set up my router.Model WRT54G
  • Anonymous Dec 29, 2007
    cant remember my password either.
  • mamacarmen Jun 28, 2008
    I forgot my passwor for the router. What can I do?
    Thanks!
  • 46 Answers
OMG BearWeb.... that was a great guide for the configuration....
But if you want to reset the router, just press the 'reset' button for about 5 or 10 seconds, and the router will return to the 'default' settings (you will have to configure it again OK?)
you can get the user guide from here:
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapper
Posted on Jun 29, 2008
    President:
  • 357 Answers
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter Linksis wireless computer setup for WRT54G model - 82e145a.jpgbr />in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appeaLinksis wireless computer setup for WRT54G model - a443500.jpgitself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select theLinksis wireless computer setup for WRT54G model - ea4fa3a.jpg Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties buLinksis wireless computer setup for WRT54G model - 6cbaf1a.jpgrc="http://i.fixya.net/uploads/images/ea4fa3a.jpg" alt="ea4fa3a.jpg" class="h_mi" />
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP)Linksis wireless computer setup for WRT54G model - 9297bc0.jpg
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start Linksis wireless computer setup for WRT54G model - f2e300e.jpgthen the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
2. Select the Local Area Connection icon for theLinksis wireless computer setup for WRT54G model - dad0f1c.jpg Ethernet adapter (usually it is the first Local Area
Connection listed). Linksis wireless computer setup for WRT54G model - 076b379.jpgk the Local Area Connection. Click the Properties button.f2e300e.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
How to connect my laptop to wifi
Posted on Dec 28, 2007
I can't remember my password when I run the setup disc for my router. It's a lynksys WRT54G
Almost every consumer router has a 'reset' button that is inside a small hole on the back of the router. It is labelled 'reset' and typically needs to be held in with something like a paper clip gently inserted and held for about ten seconds with the power on. Sometimes there are variations on this theme that are in the manual.
Almost every consumer router is supported on he manufacturers web site. Most of them have online manuals that can be viewed on the site or downloaded and read on your computer in a PDF.
You go to the manufacturers web site and enter the model number into a search box. Poke around until you find the manual and browse to the factory rest section.
Jul 29, 2012 | Linksys Wireless-G WRT54G Router
Setting a password to my wireless router
just click on your wireless setting at the bottom right of your computer it might be under hidden click on to your wireless settings in there it says set your security pass word put a pass word in and remember it and thats it
Dec 13, 2011 | Linksys Wireless-G WRT54G Router
I cant find my password
Are you looking for wireless network key WEP WPA ?
For this you will need to check the wireless settings of your network.
Connect one computer to the router with the Ethernet cable. Open the setup page and check the settings.
Dec 12, 2011 | Linksys Wireless-G WRT54G Router
I just bought a ps3 and i dont remember my key password
If you go to the setup screen for the router. Access it by typing 192.168.1.1 in your address bar for your web browser. Then go to the Wireless tab then the wireless security tab it will show you what your pass key is.
Dec 13, 2010 | Linksys Wireless-G WRT54G Router
How do i make my unsecured network secure? using linksys WRT54G v8
Access the setup page of router by typing 192.168.1.1 in the address bar.
By default, leave the username blank and the password is admin.
Once on the setup page, go to Wireless. Under Basic Wireless settings, change the default SSID Linksys into any name. This will allow you to easily determine which is your wireless network.
Then go to Wireless Security and enable WEP. Type a passphase and click the generate button. Take note of the Network key. Remember that you will use this network key to all wireless computers.
On your wireless computer, view the available wireless networks or site survey. Select your SSID and enter the network key to connect.
I hope this helps!
Jun 20, 2010 | Linksys Wireless-G WRT54G Router
Need to reset password on setup cd
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that
computer.
router set up page is the page where you can check all the
router settings.
Click Here for more information about the routers and
network
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
Just received the WRT54G router and wireless card from a friend...the router works, but I can't get the wireless to work without the original password, however my friend can't remember it. Since i have...
You can reset to default factory settings.
check here for a full list of default password
or follow these instruction:
"f you have forgot the default password of your linksys WRT54G router than remember that the default password for WRT54G is user name = not required /give any
password = admin
and the default access IP of WRT54G is 192.168.1.1"
and here for a configuration tutorial of your device.
Of course resetting values you have to recreate network configuration this tip can help.
Aug 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
I dont remember password
In order to know your password you have to:
1) Use some program to reveal the pass
2) Get access to your router
To get access to your router do this
1) Open your browser
Type .......
http://192.168.0.1
user = admin
pass= (blank) no password
hit enter
Once inside go to Wireless and see which is your WEP password
That's it
If your wireless router have a different pass than default you need to reset the router
Oct 29, 2008 | Linksys Wireless-G WRT54G Router
Wireless router pass word
sakoz,
You have to reset your router. There is a small reset button on the back, which you have to hold in for at least 15 to 20 seconds if I remember correctly.
You should be able to then log back into it with the factory preset it came with.
Please let me know if this helps. Good luck!
Mar 01, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
494 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
