AEG Favorit 50500 Built-in Dishwasher Logo
Anonymous Posted on Oct 17, 2009
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
  • Anonymous Mar 13, 2014
    AEG electrolux favorit
  • Anonymous Mar 27, 2014
    the drain pump run for many timeand after the diskwasher stop with appearence of indication 20 (model favorit 52860).
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2539
Points
8
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
  • geraldine590 Jun 28, 2011
    fantastic - it worked straight away.
richiearnold
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 20, 2010
richiearnold
Contributor
Level 1:
Answers
Questions
Helped
2558
Points
8
The solution to fix this problem is to tilt the dishwasher on a 45 degree angle to remove the water from the base which will reset the flood switch , however this is only a temporary fix . Yuo need to take the outer casing off (easy enough) and see where the water is coming from with my one it was the big white plastic container on the side of the unit sealed it up and hey presto all good cheers [email protected]
  • Anonymous Aug 02, 2012
    You deserve a Nobel prize for this. Thank you very, very much.
Kevin
Level 2:
  • Expert 79 Answers
  • Posted on Oct 17, 2009
Kevin
Expert
Level 2:
Answers
79
Questions
Helped
74912
Points
285
This can only be the controller.
Only the controller (timer) turns the pump on and off.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Testimonial: "very quick, thankyou"
  • Pavel S
    Pavel S Jul 08, 2016
    How can it be the controller if my dishwasher is switched off? Ta.
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher?
It should first be checked for correct water inlet hose with safety valve. After connecting the double-walled water inlet hose, the safety valve is next to the tap. Therefore the water inlet hose is only under pressure while the water is running. If the water inlet hose starts to leak during this operation, the safety valve cuts off the running water and the draining pump in the dishwasher is switched on. If the inlet hose with safety valve working correctly than could be some of following faulties.
  • The door of the dishwasher is not closed properly.
  • Mains plug is not plugged in.
  • House fuse in defective.
  • In the case of dishwasher models with start delay
    timer: A start delay is selected.
If you look at the lower electrical diagram then you can see that all electrical components are located in a circuit inlet valve which can be also faulty.
  • ON/OFF Switch
  • Door switch
  • Program controller (Timer)
  • Pressure switch
  • Inlet valve
  • Float switch
  • Wiring between all this components
Dado
I have a AEG OKO Favorite 675 dish washer and if you start it or open the door it sounds as if it is just draining all the time, what can be wrong?
Hello Barbara, I have one of these dishwashers and this is what happens. There is a drip tray in the bottom of the machine that catches any leaked water. There is a float switch in the drip tray that detects water in the tray. If there is water in the tray, the float switch turns on the drain pump. This will immediately pump all of the water out of the machine and keep the pump running until you remove the water from the drip tray. The pump only pumps out the machine but does not pump from the drip tray. Also the pump will keep running even if the door is open or if the machine cycle is stopped. The only way to stop the pump is to turn off the electricity supply. But also turn off the water supply at the same time, because if the valve that feeds water into the machine is faulty, it will fill the machine till it overflows and if the power is off the float valve cannot turn on the drain pump. On this machine, the solenoid valve that let\'s water into the washer is at the end of the inlet pipe when is connects to the water supply. It is powered by line voltage (230 volts in our case). If this is faulty, it can be replaced with a commercial solenoid valve. The is a two core cable running inside the outer plastic pipe on the inlet pipe. This carries the power to the solenoid valve.
To empty the water from the drip tray, remove the panel from the front of the washer. It is below the front door and has two screws on each end. When you remove this you will see a hole on the left that is big enough to put your finger through and feel if there is water in the tray. If there is, push through a small plastic pipe and suck out the water. It does not take much water to switch on the float valve, maybe the door was not closed properly and some water leaked into the bottom of the unit.
I gained the above knowledge by bitter experience.
Aeg oko favorit 40300 service manual
Please help
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
15helpful
3answers
Drain pump keeps running AEG oko favorit
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
