look at the capacitors around the processor and heat sinc the tops should be flat if not they need replacing if so you could need a bios flash if you had troubles shutting down and start up you need bios flash if not to late already
Comments:
Oct 17, 2009
- look at the capacitors around the processor and heat sinc the tops should be flat if not they need replacing if so you could need a bios flash if you had troubles shutting down and start up you need bios flash if not to late already
I have installed Win 7 on a separate partition, dual booting with my previous XP. I find that, to...
(More)
I have installed Win 7 on a separate partition, dual booting with my previous XP. I find that, to get any audio output in Win 7, I have to connect my 'line out' jack to the pink 'microphone' socket instead of the green 'line out' socket. When working with XP the connection has to revert to the original green socket. Can you give any advice please. J.A.C.
how do I do a manual reset to factory defaults. I overclocked in bios without thinking.
Soyo...
(More)
Soyo SY-K7VME motherboard.
GA-MA785GM-US2H motherboard wont boot. using PNY DDR2 PC2-6400 RAM. Power supply works fans on just...
(More)
GA-MA785GM-US2H motherboard wont boot. using PNY DDR2 PC2-6400 RAM. Power supply works fans on just wont boot. DOes this RAM work with this MB.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
