Question about Frigidaire FDE336RE Dryer
Clothes getting caught between Tub and wall inside dryer
I saw something very similar to this on a Kenmore Stackable but don't know if simply replacing the rollers on it will fix the issue. Can anyone offer a YA or NA on that same solution to fix this Frigidaire Tub issue? Thanks in advance.
  • Tazzin Dec 30, 2007
    Do you by chance now where to get a parts manual to see what part(s) are need to look for? I know i have the manual around here some where but don't know if I have a manual that shows the dryer in 'exploded' view to see how the parts are attached and what all is in volved with installation. Thanks in advance (again :D).
    Tazzin
  • Anonymous Jul 03, 2008
    clothes get caught between the tumbling wings and the outer edges of the tub
  • 625 Answers
There is uaually a rubber or composite gasket that fits inside the dryer drum with the front cover in place. the "rollers" as you call it is just pieces of felt glued to theexternal drum and front face and are the drum bearings. check appliance repair parts for the proper gasket and how to mount it to your front panel.
Posted on Dec 28, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Dec 30, 2007
    www dot partselect dot com is the best I can offer.
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
Dec 12, 2016 | Kenmore Washing Machines
I have a Kenmore thats about 10 years old. Model No. C110-6070092....type Dr-4 stackable. It gets too hot to touch inside the back wall, so hot that I have to yell "OW!" Can this be repaired,...
I don't have that model number repair manual so went to the Sears website and plugged that model number in and it says they don't recognize that model number.
Jun 09, 2011 | Kenmore Dryers
Clothes get caught/pinched over the door. The tub seems to be resting on the top of the inside over the door
Drum support has collapsed
You need to replace either the drum bearings or the drum spider
You need a man that can !!
Jul 09, 2009 | Kenmore Dryers
Something caught between the Tub and asket. How do I get access?
iots only 1 trick i know..taking that this is a piece of clothes..take the bottom front panel off..ane remove the tub to pump sump hose,,that will give you a 4 to 5 inch hole to work form..try and push what ever it is towards hole...onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Clothes getting jammed
When this model has the problem of clothes getting caught, the most common reason is the felt and glides are worn and should be replaced. Unless the clothes have been getting caught from the first time you owned this dryer, I would explore that first.
Please ask more questions if needed. Good Luck.
Aug 31, 2008 | Frigidaire GLEQ642A Electric Dryer
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
132 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
