Question about JVC Cybercam GR-DV3000 Mini DV Digital Camcorder
LCD Monitor on my GR-DV3000
I went to use my camcorder today and when I open the monitor it did not come on. I closed it and tried again. The camcorder functioned normally except for this one feature. I just used the camcorder a couple of days before with no problem. It has been safely in it's bag since then, please advise.
Sean
  • 2,427 Answers
CHECK YOUR RECENT PREMIUM QUESTION I POSTED OTHER LINKS AND DATA THAT WILL HELP YOU
Posted on Jan 06, 2008
SOURCE:
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
3.5 in monitor is not working
let it set on for a few and see if it works sometimes it takes a few to work
Jan 04, 2008 | JVC Cybercam GR-DV3000 Mini DV Digital...
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
No picture or image from lcd monitor or view finder when opened
the connection between the lcd and the main board is defective, the video connector is broken, try to use tv connection to check if you get a picture displayed on your tv screen so you need to repair your lcd. if you don't see any picture it's main board problem service is required. thanks.
Dec 24, 2010 | JVC GR-D22U Camcorder
Image is inverted in display
This model has feature(almost all JVC models) that will invert the image on LCD Monitor in order for you to shoot video yourself while watching in the monitor or even the subject. But sometimes, frequent closing and opening of the LCD Monitor damaged the flexi wire thus closing and opening of the swithes won't reached the CPU. Erroneous info occur so as the outcome. Visit JVC Service Center near you, parts is hard find if you let somebody else do. Hope it helps
Feb 28, 2010 | JVC Cybercam GR-D70 Mini DV Digital...
No picture coming thru on lcd monitor or viewfinder. Lenscap-on advisory is displayed tho lenscap is not on. All camera setting dispays on monitor are OK. Screen just blank with power on auto or manual. On...
Further research indicates this is a common problem with JVC camcorders.
If it were a car there probably would have been a factory recall. I'm sending it to JVC Service,1500 Lakes Parkway,Lawrenceville,GA 30043 for repair.
Jan 31, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Lens Cap Error
You have a defective CCD imager - the part of the lens that receives the image. Will need to be replaced.
Aug 03, 2009 | JVC GR D650US camcorder
JVC camcorder loose LCD monitor screen
I have the same problem with my panasonic palm camcorder, help...
Jun 28, 2009 | JVC Video Cameras
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Cables for my GR-DV3000
check your other post, i posted links and other information that will help you
Dec 28, 2007 | JVC Cybercam GR-DV3000 Mini DV Digital...
JVC Cybercam GR-DV3000 Mini DV Digital Camcorder Logo
52 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
