Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Overscan is there a way to adjust the overscan? i am missing text from top and bottom.
  • bengalfan909 May 11, 2010
    I have the same problem but these menu options don't work for me. The only thing I seem to be able to get into is menu 123 which is a restore factory default menu. I don't want to do that. Should these codes work with the ws65313 or there others I could try?
  • 373 Answers
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Posted on Dec 28, 2007
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
Overscan
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
Dec 09, 2012 | Mitsubishi VS-50111 50" Rear Projection...
Setting up tevion receiver
I did not find the Overscan, however I changed the TV settings, hdmi to digital, and this worked. Also, I did have part of the screen missing. I called the Tech Support to setup my Mac Mini and they adjust the Overscan on the Mac System Preferences, all is fixed. Thanks for yawl help.
Jun 03, 2012 | Televison & Video
Can you adjust pincushion, overscan on Sony kdf46E3000?
Steve, I am not an expert on this model but I can provide a link to the manual that may be helpful. It is a PDF format and the pages that refer to your issue are 32-36. I hope this assists you in resolving your issue. Thanks for using Fix Ya.
http://www.retrevo.com/d/ds/progress?doc=422217ceb653da53024f151f0e38f2ce&rk=0.4228925186481609
May 15, 2012 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
The picture has ''zoomed'' out. can't read text on scroll bars. fuz
Please try using the zoom button on a universal remote. The button on the remote may no longer be working. Otherwise the best way is to open the set and test each capacitor and transistor with a multimeter to see which ones if any need to be replaced.
Mar 25, 2009 | Sharp 27U-F810 27" TV
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
OverScanning???
it sounds like a pin-cussion correction circuit failure. A tricky circuit to troubleshoot even for an experienced tech. check servicemanuals.net for info
May 14, 2007 | JVC AV-32F475 32" TV
Auto Convergence failed becuase PS52800 failed to detect one of my Sensors?
The overscan would certainly cause auto convergence failures since the beam the CRT's shoot out are on the corners and upper center and lower center. Being too dark can also cause issues since one of the CRT beams might not be bright enough for the sensors to register. I would first have someone adjust the vertical size if the top and bottom of the frame are somewhat cutoff.
Feb 19, 2007 | Proscan PS52800 52" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
1,783 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
