I want the code to play Zone 2 DVDs on my DVD player
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Turn ON the DVD player.
Press FORWARD button on the DVD unit itself (not the remote control) until the RESET menu appears.
Select language, 1 = English (using the remote control - press the 1 button).
Then press REPEAT on the remote control (NOTE: use the REMOTE key at the bottom of the remote control - ignore the one market Remote in the number buttons - it won't work) and key in the Region 4 password = 7 6 8 8 4 using the remote control.
A number "4" will show on the top left hand corner of the screen.
Then press 9 on the remote control to make the DVD player Multi Region (a number 9 will display in place of the 4).
Exit the menu and restart the DVD player.
Simple as that.
Excellent solution.. Wonder why Samsung or for that matter any other OEMs make it a region-free player to start with!!
