Apple iBook G4  PC Notebook
Problem for Apple iBook G4 (Z0AZW13397068) PC Notebook
Installed a new internal hard drive and when I try
By miowebdesign on Oct 17, 2009
installed a new internal hard drive and when I try to boot up the machine does not recognize the new hard drive. There is no item in the select which drive to load from.
Comments:
Oct 17, 2009
- Thank you. your tips help me get farther along and Apple gave me the rest once I was able to recognize the hard drive.
Clarification Request
Posted by milleraba on Oct 17, 2009
Did you reload the operating system?
Best Solution
posted on Oct 17, 2009
Very Helpful)
Smooth_Gecko
Rank: Wiz
Rating: 81%, 165 votes
Boot off the install disk with nothing else attached to the PC. ( external hard drives especially ).
Choose ‘Terminal’ in the ‘Utilities’ menu
Then (substituting the correct values for your setup), type:
diskutil partitionDisk /dev/disk0 1 GPTFormat JournaledHFS+ my-hard-disk 111G
It’s all one line and hit return at the end.
You should see progress information, followed by a neat table giving the new formatting that has been applied.
‘/dev/disk0’ is how the operating system refers to the first whole disk in the system.
Then, the ‘1’ here signifies that you want one volume only on the drive.
Then, replace ‘my-hard-disk’ with the volume name you want to use. This is the name of the disk as it appears in the finder.
Replace ‘111G’ with the size of the disk in gigabytes. It’s usually about the same as the disk, and as the partitioning software will stretch a single partition to fill the disk it doesn’t matter too much. 111G was the value used for a 120GB HDD, because I knew that it wasn’t really 120GB.
Hope this is of some help.
If not a solution ( hard one to do over the net :) ) hopefully it will point you into a solution.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" The help I received was essential in fixing the problem I was having with my new hard drive. Thank you. " - miowebdesign
Solution #2
Not Rated)
smartr10U
Rank: Guru  Apple Expert
Rating: 87%, 512 votes
I would try booting with your Mac OS disc and when you get to the dialog box to install Mac os, instead find the Disk Utility in the upper menu.
Attempt to mount the new drive thru Disk Utility. If it doesn't show up, it may be that the ribbon cable didn't get connected properly when you installed it. You may need to open it back up to check your connections...
K
Was this helpful?
Yes
No
Popular Solutions for Apple iBook G4 PC Notebook
Questions and Unsolved Problems for Apple iBook G4 PC Notebook
Do you recommend Apple iBook G4 (Z0AZW13397068) PC Notebook?
Answer
Answer
stuck when boot on level 67. Dell L 610
Answer
i cannot activate bluetooth in packard bell easynote tj65 running windows 7
Answer
While is was searching on the internet my iBook G4 locked up. I tried to reboot and it locked up... (More)
Answer
my ibook g4 locked up one day while I was on the internet. I tried to reboot, nothing. I tried to... (More)
Answer
my mouse wont move, im using my friends computer.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iBook G4 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
