ACE Stanley& Pocket Powerlock Tape Rule  Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install tape How do I install tape in powerlock 10 ft. tape
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Oct 17, 2009
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2053018
Points
24677
Pull it all the way out ... have a nail ready to put into the hole just past the end on the tape, in the spring. Remove the tape. Install the new one (insert the tang into the hole and twist). Remove the nail and carefully allow the spring to pull the new tape in.
I hope this works for you
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
Tip of my Stanley PowerLock 25' broke off. Is it repairable? Yes the tape slid back into the housing.
You can put it back on but depending on how it broke and how you reattach the measurement will be off a tad.
1helpful
2answers
How o figure sq ft of my home and bedroom
I don't know how to deal with it because I hired special people for it. The only thing I did myself - I chose the design. I adore the grey colour and that's why I was looking at rooms with grey walls on https://kudoshouse.com/best-83-grey-bedroom-ideas-gray-bedrooms-with-images/ and I am impressed by these ideas!
2010toyotatundra powerlocks and powerwindowsdo not work
fuse blown.
check fuses.
some cars have circuit breakers on window motors.
if one motor shorts the breaker pops but then resets.
i use a voltmeter to find lost power feed.
its easy.
check voltage to motor, got 12v , when active (swith closed?)
no, then check at the switch, got 12v at switch input and output
with switch active,
yes, then wire is cut from switch to dead motor.
no, then wire is cut from input to switch and fuse.
like that. its not hard at all to use any voltmeter even a $10 meter at walfart.
3helpful
2answers
Dear expert What are the cylinder head bolt torque settings for the 4.0L MFI straight 6 engine? Regards Dave
Here are the specs and sequence:
Install the cylinder head and bolts. The threads of bolt No. 11 must be coated with Loctite® 592 sealant before installation. Tighten the bolts in 3 steps, using the correct sequence:
  1. Tighten all bolts to 22 ft. lbs. (30 Nm).
  2. Tighten all bolts to 45 ft. lbs. (61 Nm).
  3. Retighten all bolts to 45 ft. lbs. (61 Nm).
  4. Tighten bolts 1 through 10 in sequence to 110 ft. lbs. (150 Nm).
  5. Tighten bolt 11 to 100 ft. lbs. (136 Nm)
  6. Tighten bolts 12 through 14 to 110 ft. lbs. (150 Nm)
I have a Stanley Powerlock 25 ft. tape that broken at the 6 ft, mark where do i do to get if fix
those are garuanteed for life,as long as it was product defect.I take mine to local hardware store for replacement.Been 5 yrs. since I bought one.
I have a Stanley 12 ft. Powerlock tape model # 33-212. The plastic thumb locking trigger just broke. Can I purchase a new one and if so where?
No. You'll have to replace the tape measure, or find another similar model to rob the part from...See here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
What are the best tapes to buy to recrod from your reel to reel. I have some tapes that record and some don;t. Is it becaue they old or defected. Help me out. vp
maxell or tdk (which is hard to find now)....if your reel is 7 inch you want 1800 ft, normal bias (lo noise hi output) tape (for 10 inch you will use the 2400 ft) ....anything longer your tape will be dragging (both while recording and playing) hope this is helpful...feel free to rate
Top ACE Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you an ACE Measuring Tool and Sensor Expert? Answer questions, earn points and help others
