Question about Canon Pixma MP500 All-In-One InkJet Printer
Black line on back of page
After printer has sat for a few hours the first page printed has a 1/8" wide black strip down the back of the page. It is worse in the beginning and is almost gone by the end of the page. Any ideas?
  • Canonmother Jan 01, 2008
    I am having this same problem nearly all the time. Black line down back of the page. I have taken the cartride out and tried to se if any ink was in the cartridge holder.
  • heervanstand Feb 04, 2008
    Same problem, black ink trail on the back of first print page. It fades in the next prints. Seems to relate to an overfilled waste ink container, didn't know there is such a thing on a printer. They do spill that expensive ink then, is that right?
    Since I'm a very clumsy do-it-yourself type, I plan to call on a Canon dealer for help. Will let you know if it worked out well.
  • 3 Answers
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Posted on Jan 15, 2008
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
I'm getting a straight line of no text or image running from the top of the page down to the bottom of the page. The print started getting fainter and fainter until there was no print at all in a 1/8 to...
Please run a printer alignment exercise. Then do a print head cleaning exercise. If these does not solve the problem then try to reset you printer. Clear the printer memory. Please follow the user manual to perform the steps.
Dec 21, 2010 | OKI C5100 Laser Printer
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
When printing, a black stripe is printed on the back side of the printed pages (about 1/4'' wide, running from top to bottom). The ink strip bleeds through to obscure printed side. Any suggestions?
You need to have the exit rollers cleaned at a shop, and a mylar strip added to keep that from happening again. It's the ink from the cleaning station backing up thru the exit rollers.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Canon MP500 printer
We have the same problem. I removed the cartridges, then removed the print head. There was lots of ink gunk on the print head. I cleaned it and the problem disappeared completely for a few days but is now back. I suspect the print head needs to be replaced. Still working on it.
Apr 11, 2008 | Canon Pixma MP500 All-In-One InkJet...
Copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Jul 06, 2007 | HP Photosmart 2575 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
364 people viewed this question
old marine
old marine
