Question about Panasonic PT-51G42 51" Rear Projection Television
Panasonic pt-51g42v i have a problem with the vertical on this tv it appears image is too big for the screen. i have read that the tech menu has some adjustments for this but how do i access the tech menu. i have called repair shop they said it would cost $250-$350 i can buy a new tv for less than $900 so i don't think i'll take it in. if i can't fix this myself i guess i'll trash this one. i want to try the adjustment or if i can find the pc board for the vertical i can replace it i have a service manual but doesn't really tell what each board controls. thanks for any help with this problem. and have a happy new year!
  • 373 Answers
You might have bad solder joints on the vertical output IC. I do not know where it is located in this set only that it will be mounted on a metal heat sink near three wires that have identical plugs which go to the deflection yokes on each crt tube. Sets vary as to placement of vertical IC. Solder joints should be easily seen if you have good eyes or use a magnifying glass. I do know that the vertical IC will be on the board that has the highvoltage transformer on it (has big red wire). You may have to unplug the board and turn it to the soldered side or just turn the entire chassis up 90 degrees to see the connections. If this is not the problem I don't know how to get into the service mode at this time.Hope this helps
Posted on Dec 28, 2007
How to reset lamp w/o remote panasonic pt-52lcx16
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more:
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
Picture has a black image (box that black out part of the screen) that comes on seconds after TV is turned on, leaves when volume is adjusted, then returns after a few seconds. Does not appear when Wii is...
You need to go into your menu and go to close caption and turn off the text screen that some how got turn on, that big black box is call a text screen, and you are not the first person that this has happen too, Take care.
Jan 09, 2011 | Panasonic PT-51HX41 51" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a PT-47WX53 rear projection TV that has a 3-4 inch vertical bar that is in a purplish hue. Barely visible. Asking for suggestions of repair. Thanks.
There is one very common problem for this--the band of noise appears after the set is on for a few minutes but you have no picture?
Panasonic ECWF2474JSR C509 CAPACITOR .47UF 200V
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
Picture Stretch on Panasonic PT-53WX54
Usually this is an indication of a failing capacitor in the vertical circuit. Have those been checked? I would look for 100ufd caps in the vertical circuit. Check with the tech.
Jun 02, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Projection off the screen?
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Feb 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
Jul 30, 2007 | Panasonic PT-56LCX66 56" HDTV
Neon Pink outlines around bright images
two points one green and another pink one in the screen Panasonic PT-61LCX65
Jan 30, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
196 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
