Wavy picture for Toshiba Model 50H12 Rear projection TV
When I turn on the TV the picture is wavy. After approx 10 minutes it settles down and bocomes steady. What do you believe is the likely problemand the approximate cost to fix it?
  • 1 more comment
  • Ed55 Dec 30, 2007
    I had the same wavy picture. It started out lasting only 10-15 minutes, but now it lasts all the time.
  • mgrosh Nov 10, 2008
    I'm also trying to find a solution to the wavy picture for my Toshiba 50H12.. It started out lasting about 5 minutes but now takes about 15 - 20 minutes to go away. I wonder if it is soon just going to stay that way?
  • Anonymous Apr 14, 2009
    same problem with mine, wavy started at top of screen now is worse best buy geeks said can't be fixed, can't get parts.
In general, these problems are usually caused by leaky output filter capacitors in either the low voltage power supply or, depending upon the type of waviness you're attempting to describe, it could be in the vertical deflection circuits (either the vertical oscillator or vertical amplifier). I would estimate cost to repair from $200 to $350 dollars, depending on how long it takes to find the problem. It most likely though is a component issue in the circuitry.
Posted on Dec 28, 2007
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
When you turn on the the TV the picture is good with in a minute or so the Picture turns wavy and has a double image. I can turn it off, then turn it right back on the picture is good for any where a...
The problem with the television is the lamp. It is faulty that is why the screen turns wavy in minutes.
The solution to that is to replace the light and your television will be in good condition once again.
Take care
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
46'' Toshiba HDTV
It needs the Scan Converter Module repaired or replaced. It usually has dry capacitors that need replacing
Dec 14, 2009 | Televison & Video
The picture is wavy and the audio sounds muffled. TOSHIBA 50H12
The first things that come to my mind is tuner check the tuner, check and play dvd's if its still the same a tuner board will need to be replaced.
Jun 26, 2009 | Toshiba 50H82 50" Rear Projection...
Wavy Lines which clear up after being on for 10 minutes - Toshiba 50H82
It will cost about $300 to fix. The Hyperboard has to be replaced. I had it repaired over 2 years ago and it works great.
Sep 06, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H12 Rear Projection TV wavy screen
There is a Hyper Module mounted right behind the video inputs board. in most cases you can replace the 10uf surface mounts carefully not to tear the foil. and the set will return to normal. or replace the H/M board. this board is soldered 4 tabs on bottom of main board and then pulls out. good luck list of caps cz52(may not have this cap).. cx261 cx270 cx230 cx178 c514 cx221 cx250 cx241 cx541 cx670
Dec 11, 2007 | Televison & Video
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
