Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Ice maker is not working but water dispenser is.
I had a big party and the ice bucket was emptied the following day it was still empty. I checked to make sure everything was connected properly and from what I saw it was but still NO ICE. Please help if you can.. How do you know if the infra red sensor is working?
  • 6 more comments
  • wwc10 Dec 28, 2007
    I still get water out of dispensor. I put a new filter on the box.
    Freezer freezing food and ice cream. Ice maker teflon coating coming apart inside where ice is made.
    Tubes are connected good one is 1/4" and one is 3/8". Supply line goes to filter fist.
    The ice maker is mounted sideways. I pulled it out cleaned it and put it back in. Still not making ice. Tube supply comes down from right side.
    The ice maker is switched on. There is a red light flashing on the right side. When I hold the plastic door on the left the red light stays solid.
    I tried to swap the cables different size terminnals.
    The icemaker is tan solinoid 35w. The water is purple 20w. I get 350ohms on the purple and 228ohms on the tan. Meter set at 3oo.
    Nothing has been solved yet.
    Scholar:
  • 135 Answers
Is there water in the ice maker mold or is it completely empty? If there's no water in there, check if the supply shutoff valve is turned on. Also, try connecting the tubes directly to the ice maker without going through the filter first. If there's still no water in the ice maker, your tube might have gotten clogged - you should try cleaning or replacing it.
Posted on Jan 08, 2008
  • 319 Answers
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
  • Brian Berndt
    Brian Berndt Jan 08, 2008
    I am guessing that you have already tried to clean any debris/frost from the emitter/sensor. If you haven't, you may want to try that first, however, an power off, wait, then power on may still be recommended.
  • Brian Berndt
    Brian Berndt Jan 10, 2008
    Did you try the Self Diagnostics that I provided? What did you find?
    Brian
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
All of a sudden my ice maker is not working. The
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
vxnqer
May 13, 2010 | Hotpoint HSS25GFP Side by Side...
heatman101
bvvc
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
My ice maker stopped working. Yesterday I emptied the ice bucket as a bunch of cubes were frozen together and it would dispense. I've turned it on and off but nothing. There is no ice in the bucket and the...
You need a new water valve on your LG fridge. This is a simpe repair and we have parts so just contact us with your beand and model number.
We look forward to working with you.
Nov 04, 2009 | LG LRFD25850 French Door Refrigerator
Ice maker
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
Thanks
Vic
May 11, 2009 | Refrigerators
check for right direction on the filter,check the water intake solenoid valve.water presure.check that the bin is seated properly and all interlock switches are closed and working.
Nov 05, 2007 | Refrigerators
check you havent put icemaker onto vacation mode.. also if it has infra red sensors at both sides of ice maker unit , these can go faulty.. ally
Jul 02, 2007 | Whirlpool ED5SHAXM Side by Side...
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
464 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
