Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
I only have two settings. Which is which and how so?
By jconstante31 on Oct 17, 2009
HI. On my AC/Heat unit, I only have TWO settings... EM HEAT (which I was told stands for EMERGENCY MODE HEAT) and AUX HEAT? What does AUX HEAT do? Why is it called AUX? Doesn't AUX stand for "secondary"? Wouldn't the EMERGENCY MODE be the "secondary" one though? I'm confused. I need specific answers. No offense but will the real GURU's please reply?
Best Solution
posted on Oct 17, 2009
Very Helpful)
1fastbob
Rank: Guru
Rating: 90%, 106 votes
I think you probably have a heat pump. Aux heat is electrical resistance heat coils that produce heat when the heat pump can not produce enough to keep the temperature up (caused by low outside temperature or a problem with the refrigerant system). This resistance heat can be switched on by the emerg. heat button. It also can come on automaticlly (sp) and will be indicated by the aux being shown on the thermostat. Sometime if you set the heat up several degrees by thermostat the aux will come on to help the system catch up to the desired temperature setting. The emerg. heat is a way to turn on the AUX manually. If you do not have a heat pump system then it is possible that you have a heat pump thermostat installed on a non heat pump system. Emergency heat and Aux are both the secondary.
Hope this makes sense1
Bob
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" So in other words, either my thermostat is mismatched or I actually have THREE heat settings. Thanks a lot Bob. Your input made all the difference. " - jconstante31
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
