Question about Brother MFC 420CN All-In-One InkJet Printer
Double-vision printing Occurs with normal b & w or color printing. Removed bidirectional printing from setup but didn't help.
  • byerssm Dec 28, 2007
    Multiple cleaning cycles and new cartridges have not helped.
  • byerssm Dec 29, 2007
    For others who may encounter this...
    Found out there is a head alignment fix under "ink/test print/alignment" that was not listed in user manual index. Did the procedure and printer works fine now.
Your printer heads are incredibly dirty and need to be cleaned. Buy inexpensive G & G ink cartridges (Printer Country.com is a good source), and don't be afraid to keep cleaning. If it shows no signs of clearing up after 15-20 cleaning cycles, then you'll need to disassemble the printer to try it manually.
Posted on Dec 28, 2007
Dear Mr. / Mrs. , I encounter a big problem with my print server edimax ps 1206U .actually i work in a company that in one of our departments we have a HP color laserjet cp 1215 printer and our OS is...
Most of the print servers (1206u as well) do not support bidirectional printing, which actually allows the computer to printer bidirectionally so that printer info (toner status, print status) is sent to the computer.
Open Devices & Printers
Right Click on the CP1215 and go to printer properties
On the Ports tab, remove the tick next to the "enable bidirectional support"
Apr 26, 2011 | Computers & Internet
LEXMARK z12 IS PRINTING SAME LINE TWICE LIKE
uninstall/reinstall the printer software and drivers
Sep 14, 2009 | Lexmark JetPrinter Z12 color InkJet
The only issue with it is it has a double vision screen (The colors are kinda messed up)
JUST GET MAGNET AND TRY TO PASS IT BY THE SCREEN, OR GET IT CLOSE TO THE MESSED UP COLORS, I HOPE IT WILL HELP, LET ME KNOW IF IT WORKS
May 13, 2009 | Samsung PCH521R 52" Rear Projection...
Double vision on color only
I like the Tech Most likely did a Color Configuration , Go into the Menu and Use the Arrow keys to scroll and look for " Color Calibration " run the test make sure you don't have " Bleeding" this is a term used by Color Tech's like myself to describe that Color are mixing together which is causing your current problem.
Do calibration First.
Mar 09, 2009 | HP Color LaserJet 2600n Printer
Double vision
If you are printing color and you have color blurring like streaks. it mean the registration of the colors are off. Usually using the internal cleaning function from the panel will clear this up. You should restart the copier as well. If it continues check all the feed rollers.
Feb 12, 2009 | Canon imageRUNNER C3220 Color Copier
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Siemens 2614
The printer port on 2600 series routers does not support bidirectional printing. This feature should be disabled for the product to function normally. See Related Articles at right for further information.
  • Solution
    To disabling bidirectional printing:
    1. Go to [Start > Settings > Printers] or [Start > Control Panel > Printers], depending on your version of Windows.
    2. Right-click the printer and select [Properties].
    3. Select�the�[Ports] tab.
    4. Deselect [Enable bidirectional support].
  • Hope this helps. let me know.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Jul 12, 2008 | Siemens SpeedStream 2614 Router (ss2614)
    Double Vision....
    the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
    Mar 08, 2008 | Sony KP-51HW40 51" Rear Projection...
    Printing in one direction only
    Your printers alignment is out that is why it prints only in one direction.
    Dezzi
    Oct 11, 2007 | OKI MICROLINE 521 Matrix Printer
    Double vision
    theunit needs convergence ic's
    Mar 05, 2007 | Philips 43P8341 43" Rear Projection...
    Brother MFC 420CN All-In-One InkJet Printer Logo
    313 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
