Question about Hampton Bay Sidewinder 04890 Ceiling Fan
Light problem Light will not fully come on, fan sometimes comes on by itself.
    Sergeant:
  • 263 Answers
Check and re conect wires with the wire nuts false contact or loose contacts
Posted on Dec 29, 2007
How do you reset the service engine soon light
Put the key into the ignition and turn it to "Run." Don't start the engine. Press down slowly and fully on the gas pedal, then release it. Do this three times in five seconds. Watch for the "Service Engine Soon" light to start blinking. This indicates that the system is resetting itself. Turn the ignition to "Off" and wait one minute. Start the Century's engine. The Service Engine Soon light will flash for a moment, then turn off. If it doesn't do this, repeat the process.if all else fails...Disconnect your battery for one minute and then reconnect it again that should reset it, if the problem that you have in your car is still there then that light will come on again after whille then you gona need to run diagnostics on your car to find the problem if it will not come on again then that should take care of it.9-08-2006Let me tell you about my experience with my 1995 Buick Century.When my buick sits for a while while running, the radiator fan comes on, you know?Well, after the fan does its thing, SOMETIMES the "SERVICE ENGINE SOON" light comes on.THEN.....when this happens again, it may take a couple times of after the fan comes on, then....the light goes off !!!Its like it needs to go thru some sort of "CYCLE" , THEN THE LIGHT GOES OFF...Who knows though,you may have LEGITIMATE problems with your car.good luck.
Aug 17, 2014 | 2003 Buick Century
My new monte carlo fan comes on at night by itself. Sometimes the fan comes on. Sometimes the light comes on. Sometimes it comes on multiple times after we turn it off. We do not have a remote, just
MODEL NUMBER please so I/(we) can see how your fan is controlled? RF? IR? looong string? (Sorry ~ I could not resist).
Methinks FIXA NEEDS a new category of "FANS".
Anthony
Dec 23, 2017 | Monte Carlo Fans Dryers
Fan just quit working one day. Nothing happens when I turn the light switches on and off.
Is it powered thru a light switch? Sometimes those do just quit. You can remove the old switch & replace it. Go to Lowe's/Home Depot, the switch itself is fairly inexpensive (probably less than $5). Remember to turn off the breaker to that room/switch before you do anything. The installation itself is simple - just wire + to + and ground it. Did you notice any kind of noise/smell before it stopped working? If the motor is burnt out - just replace the whole fan (unless you feel like tinkering with breaking it down & finding a replacement motor). Sometimes the lite switch on the fan itself will go out - parts for that can be found at about any larger hardware store, but sometimes that's not an easy repair (depends on what type of lite kit is on the fan). However, if that were the problem -it would not cause the blades not to turn, it would only keep the lights from coming on. Try replacing the light switch that turns the fan on/off first (the one on the wall, not on the fan itself) - hopefully that'll solve it for you. Good Luck.
Jul 13, 2011 | Hunter Fan 21623 Concert Breeze Ceiling...
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Impulse gun wont fire and fan doesnt run
could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Apr 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
The control is not working on our fan and light and sometimes comes on its own Mod No 6981-5 App No19636
If this is a ceiling fan,and it is on a adjustable control,then the control is bad.What ever kind of fan it is,if it is coming on by itself,then it would have to be the control causing it,if it is digital ,then the circuit board is bad.
Nov 26, 2009 | Casablanca Fan Dryers
Hunter Sonic Ceiling fan comes on by itself
is it your grage door opener that could be doing it
Jul 22, 2009 | Hunter 52" Ceiling Fan With Light And...
Why does our two year old fan with light sometimes turns on by itself.
If it is not a timed operation then, the contacts are getting loose or misaligned.
Nov 01, 2008 | Casa Vieja Probe White Ceiling Fan
Hampton Bay Sidewinder 04890 Ceiling Fan Logo
139 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
