Question about RCA D52W19 52" Rear Projection Television
Green Screen All inputs are green when selected. I have done all adjustments. The TV has only been moved a cople times with great care. The tint function does not work at all.
  • 308 Answers
Do you just have a completely green screen, or can you see a picture or On Screen display when selecting inputs and channels? And did this problem develop after moving the set "with great care"? Knowing RCA's reputation for building sets that develop intermittent connections after a few years, I would be tempted to look there first. Semiconductors and IC's have been very reliable lately.
Posted on Dec 31, 2007
Green tint on tv
Is entire screen green or just tint range will not move?
Look at set with color off to zero and also try different inputs.
Advise me source of signal and how or where you are connected.
Jun 13, 2012 | Seiki SC221FS 22 Class LCD HDTV
Magenta Color
Here is something that may help from the website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Greenish tint to picture
there may be a green tube issue or there could be a screen voltage or screen control adjustment issue. There is a control block with six adjustment screw inside the front panel in front of tv. WARNING high voltage exsit in this set and adjusting these controls really should only be done by a tech,....So be careful
Nov 20, 2008 | RCA D52W19 52" Rear Projection Television
Picture has green tint
use menu on remote adjust tint to center
Mar 23, 2008 | Philips 9P5034C 50" Rear Projection...
Green Tint in HDTV for the first few minutes.
Possibly adjustments to the service menu could rectify this. Also, adjustments must be made to customer settings in menu for each input. In the past I have improved or solved this by making service adjustments, however, if you attempt this, please make sure you know what you are changing and make sure you are in 1080i mode. Service code (mute,1,8,2,power on)vol+ and vol- to select an item. Use mute and the menu to adjust. Use add to save the settings. Take your time. Hope this helps.
Mar 11, 2008 | Samsung HCL5515W 55" Rear Projection...
Green tint on a SRT2232S
  • green tint & also very prominent when there is a black screen.
  • this problem is due to degaussing effct or magnetic effct in tv.
  • please remove magenatic material near tv like speaker or headphone.
  • if you have turned the direction of tv please bring to normal put the tv on & put it off for 30 minutes & now put it on it will be ok.
  •  do not turn tv when it is on
  • hope this will help.
Oct 22, 2007 | Sylvania SRT2232S 32" TV
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
Jan 13, 2007 | Toshiba 32AF41 32" TV
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
