Question about Sharp R-510HW Microwave Oven
Sharp carosel R310FK-keeps going
Worked fine this morning. Now it starts running as soon as the door is closed but it won't heat. The stop button beeps but it will not stop running. Help.
  • bothered Dec 29, 2007
    Is replacing the control panel and keypad less expensive than buying another micro?
I accidentally broke the upper hock on the door yesterday. It did the same thing - as soon as I close the door, it starts turning and the light stays on. There is a contact switch inside that needs to be activated when you close the door.
I opened up the oven and bypassed the switch. I could use it know but I need to push the clear button before start cooking. I'll have to order a replacement part now.
Good luck.
Posted on Jan 06, 2008
  • 625 Answers
Control panel is hung up - replace panel and keypad.
Posted on Dec 29, 2007
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Why does the fan on my Sharp Carosel II microwave continue to run? Model R-8560
From the description one of the door switches is defective, if you have a digital meter then I will walk you through the testing phase.
Jul 06, 2012 | Sharp Microwave Ovens
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
My Maytag Microwave, Model MMV 4205 BAS has an issue. As soon as you close the door, there is a humming sound. This is without pressing [Start] or entering any time. I have tried pressing the [Stop/Clear]...
did it come into contact with water at anytime, if yes than this is probably the reason ask an electrician to come and have a check or if it is working fine you can continue using but make sure that no liquid will spill over inside
May 12, 2011 | Maytag MMV4205 Microwave Oven
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
Constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
May 17, 2009 | GE Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Stuck on but no power
it is the problem of the faulty heating element .the heating element needs to be replaced to solve this heating problem.
Dec 29, 2008 | Microwave Ovens
Sharp R-510HW Microwave Oven Logo
188 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
