Question about Sony PlayStation Portable (PSP) Console
Weird sounds from the UMD
Okay, I accidentally dropped my psp a week ago and it started to make a sound. It's like a fast ticking sound. When I opened my UMD, a part on the right was moving by itself. It was hitting the big metal on the center. I wasn't playing a game at that moment.
I don't know what the problem is.. Please help me. Thank you.
  • 9 more comments
  • Gabbage Dec 28, 2007
    Yay! Okay, I will try to fix it myself. But would there be a risk of making it even worse?
    I'm gonna check back tomorrow to see if you replied. ^^
    Ok. What next? Thanks so much.
  • Gabbage Dec 29, 2007
    I opened it already.. And read the forum. Now what? :)
    Okay okay.. I may have to continue tomorrow. Goodnight. Thanks again.
    *Note: There's a thing in there that's got a mind of it's own. I mean it's moving and there's a circle on the moving thing which goes forward and backward.
    It's metal.. Like a small rectangle with a cylinder on the center. The cylinder part is the one that moves up and down and the rectangle part is the one that moves left and right. When I open the thing where you're supposed to put the UMD, it's located at the right side near the center. The rectangle thing hits the center part. The cylinder on the center of the rectangle makes a buzzing sound like some sort of a robot hand moving. And the when the rectangle itself hits the metal thing on the center it makes a soft noise, more like "tak tak tak."
    Do you get it or am I just making things more complicated?
    I think this is what it looks like when you look at it in front view:
    ___
    | O |
    |__ |
    Because when I look at it from the outside of the thing where you put the UMD, it looks like this.. (When the cylinder thing goes up and the rectangle hits the metal part on the center.)
    _ (cylinder)
    _________ _! !___
    (metal part) (rectangle}
    to this..(When the cylinder thing goes down and the rectangle departs from the metal part on the center.)
    _________ _, ,___
    _________ _, ,___
    _
    _________ _! !___
    Sorry for the lame way of making a pictograph. I don't have my camera right now so I cant take a picture.>.<
    Well the pictograph didn't turn out that well. So, I drew in paint. :)
    This is what it looks like in front view.
    Front
    And this is in side view.
    Side
    Wait wait, I THINK this is the one..
    http://www.vavolo.com/C/LHD-KHM-420AAA_2...
  • Gabbage Dec 30, 2007
    Well this happens when my PSP is on. I think the cylinder lights up because it looks like the light on your monitor. (Near the power button.) I looked at the UMD again and this is the exact part.. I guess.. Sorry my explanation was a bit confusing..
    It doesnt seem loose, it's just moving by itself. And I cant make it stop. And I removed everything before opening it up. My PSP is psycho.
    There's also some sort of a drilling sound..
    Like "bzzzt bzzzt taaktaak taktaktak weeew weeew"
    It's weird you know..
I am having the same problem with this.
Posted on Apr 14, 2008
Hei just take off the memory stick and turn it back again just that easy...and the fast ticking sound will be gone in a flash...just like what i did to my psp...smile..
Posted on Dec 30, 2007
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont work it doesnt read games makes weird sound
umd games or iso games if umd is problem your disc reader is broken and it costs sixty bucks to fix it if iso then reinstall custom firmware
Feb 23, 2009 | Sony PlayStation Portable (PSP) Console
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP wont play umd
Same with my PSP. My son accidentally broken a spring sensor for the UMD when you close the UMD cover of the PSP. That's why the drive doesn't recognize if there's a UMD. Sony Service Center here in the Philippines doesn't have a replacement part for this.
Aug 19, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
