How to get ride of Toner life end message. Replaced color cartridges on brother mfc-9840cdw. Message "toner life end" will not go away. Thx.
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
This works. Thanks!
Yes, it worked for me too, but I fudged. Didn't replacing the cartridge, but took it out & rocked it back & forth. Is that OK?
Thanks striekr321!! I replaced two toner colors and I kept getting the toner life end message. After doing as you suggested it took some minutes to "Warm up" but after that it worked like a charm. Thanks for sharing your solution, you made my day!!
WE ARE, WE ARE... thank all that participate in the great world wide web. This is just what the doctor ordered
