Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53UDX 10B 53in Rear Projection
Need to clean the back side of the screen where dust and cob webs have accumulated. How do I remove the screen?  Thanks for help.  Steve
    Novelist:
    Champion:
  • 232 Answers
Steve, easier and safer to remove back panels, remove bottom back cover then remove top back cover, be advised the top cover has a giant mirror on the inside so it will be heavy and easy to break, use 2 people to remove it, this way you can get at the inside and clean the mirror at the same time, hope this helps and Happy New Year, BMW Rider
Posted on Dec 28, 2007
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
HI I HAVE A SPIDER WEB IN MY TV HOW CAN I GET RID OF IT . IT REALLY BOTHERS ME WHEN I WATCH TV BECAUSE I CAN SEE IT
try to open the back of your tv but be sure to unplug it then clean the projector lens using a dry cloth cotton.
Oct 15, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Cob webs behind screen
The frame around the screen just pops off. Unscrew the plastic holders from the chassis frame and the screen will come off allowing you to clean everything inside easily. The "2" thin screens are easily cleaned and put back on easily also. Don't do what I did and think the screens go into the front slot of your plastic brace, they slide easily into the wider slot. You'll also be able to clean the dust from the reflector and guns with Windex. Much better picture after wards, trust me. You would be surprised how much dust may have accumulated on the lenses.
Jan 31, 2010 | Philips Magnavox 55P9271 55" Rear...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Removing and cleaning the screen on a 65" rear projection tv
You can remove the screen, take the speaker cover off in the front you sould be able to see the screws that hold the screen on the bottom remove the screws and unplug the wire the goes to the screen fron the tv, you need two people one on each side just pop each side up about an inch and pull it off,
Jan 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Dust buildup behind the screen
Remove speaker girll.No screws to remove grill just pull off.At the bottom of the screen frame you will see 4 1/4 inch screws.Remove screws and lift screen straight up.Clean cob webs and clean off lenses.I do not reccomend cleaning the mylar mirror.It is very delicate and you will scratch it.You can use windex to clean lenses.Good luck.
Jan 19, 2009 | RCA P52926 52" Rear Projection Television
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Cleaning Hitachi 60 " screen
Does any one have a used light engine for a 60V710 SHITachi TV?
May 23, 2008 | Hitachi 60V710 60" Rear Projection HDTV
Cob web
The cob web is likely to be on the other side of the screen. I undid the back cover and dusted the screen from the inside. I also sprayed pesticide inside the TV (wood and corners only!)
Mar 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 53UDX10B 53" Rear Projection Television Logo
200 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
