Question about Uniden TRU8885 Digital Answering Machine
Uniden powermax 5.8 handset
I have a base and 2 handsets set up in the downstairs of my house. The base and one handset work fine but the other handset will fade out while I am talking so that I can't hear the call.
  • 3 more comments
  • Anonymous Mar 30, 2008
    I have the same problem. Just one of my two Uniden Powermax 5.8 GHz hansets routinely fades in and out making it essentially useless. Tried long recharges and installed a new battery. Neither had any effect. Trying to find a place tio buy just one handset.
  • makneyse May 29, 2008
    My handset will occasionally fade out while I'm on the phone so I can barely hear the person on the other end of the line. It always comes back to a normal volume but it is very random and annoying. Whenever I'm not using it, my handset rests in the base and is always charged. Any suggestions?
  • Anonymous Feb 25, 2009
    Same deal....please help
  • Anonymous Mar 25, 2014
    The hand set has come from another uniden base not will not work on my uniden base is there anything I can do
    the answering system no longer works. the handsets say that the answering system is on. the base says that the answering system id off. how do iturn the answering system on on the base?
    New Friend:
  • 136 Answers
Place both handsets on the recievers for 24 hours so they can register to there spots
Posted on Mar 30, 2008
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
I have a Uniden PowerMax 5.8 the message light won't turn off how do i fix it
To make the message light go away when there are no messages - remove the handset from the base and press and hold the "find handset" key for 5 seconds. Resets it!
Jul 04, 2010 | Uniden Cordless Phone
Uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
Uniden PowerMax 5.8 no audio transmission on two of three remotes
If phone is more than 1 yr. old, battery needs to be replaced, if not reset base by disconnecting power, pressing and holding delete key while reconnecting power.
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Uniden dect6.0 handsets do not operate
I am writing for my Mum, who is 99. We live far apart, so it is a bit difficult to fix her problem. She had a new Uniden DECT 60 (?) installed in early July. It seemed to be working fine when we left her, but she says it only rings twice before going to voice mail. She says it has always been like that. How can we fix this for her even though we live at a distance?.
Mar 12, 2008 | Uniden DECT 6.0 Cordless Telephone...
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
Uniden PowerMax 5.8
Hooray!
Aug 04, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden TRU8885 Digital Answering Machine Logo
1,136 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
