Question about Gateway 550GR PC Desktop
Cabinet how to open & replace fan - noisy hum!!!
  • 55 Answers
Depending on which fan you're talking about usually the fan on the side or front are the easy ones to access. The front fan is a little harder but the front of your tower needs to come off. You should see release clip on both sides on the front of your tower when you remove both sides. If it's the heatsink (the one that keeps the CPU cool then you need to get one compatible and you need to buy some thermal paste as well. This paste helps discapate heat. Without it your computer will keep restarting. I hope this helps solve your problem
Posted on Dec 28, 2007
It is making a humming noise
Rear projection TV's have fans that can become noisy with age also the colour wheel motor also can become noisy. Replacing the fans should be easy and cheap, the colour wheel motor not so much.
Dec 24, 2014 | Samsung HLN5065W 50" Rear Projection...
Why does my computer humming sound
Could be a noisy fan, if so install a new fan.
Mar 19, 2013 | Toshiba Satellite Computers & Internet
Freezer fan dead?
Could be the defrosting that is not working. The fan starts touching the ice build up on the back that then causes the noise. A few days later the fan will get stuck on the ice as it keeps on building up due to no defrosting taking place. Unit will keep running as the set temperature inside the cabinet cant be reached because the air distribution will get blocked of due to the ice build up and stuck fan.
Oct 06, 2017 | Northland 24" Built In Top Freezer...
My processor fan making noisy sound, how should i fix that?
if that is an intel processor fan, i suggest you to replace rather than fix that.
its cheaper buy a replacement than fix that.
Mar 08, 2011 | Intel Computers & Internet
When you press start the microwave starts with a low hum and sounds like a bearing or fan is vibrating, micrwave still heats up and works just runs rough. Bruce
Ther is a loose peace of metal in the magnetron, it is not a big worry, it's just noisy, i have a noisy microwave and it is working fine for 10 years now, if you use the defrosting mode you should hear the noise (on and off) because in the defrost mode the magnetron energises on and off, it could be the cabinet vibrating as well look for loose peaces of metal
Jan 04, 2011 | GE JVM1850 1000 Watts Microwave Oven
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Loud humming sound; stops when door is opened.
sounds like your cooling fan if to noisy replace if not leave it alone
Sep 14, 2010 | Dacor Epicure EF42BNDB Side by Side...
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Noisy Motor
The compressor is normally pretty quiet, more of a deep hum so the noise is probably coming from either the fan that circulates air inside or the one that pusshes or pulls air through the evaporator coils under the cabinet. Probably has Chinese fan motors by now -
Sep 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Gateway 550GR PC Desktop Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
