Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
EM HEAT
By jconstante31 on Oct 16, 2009
EM HEAT.... does it stand for ECONOMY HEAT or EMERGENCY HEAT? They both conflict. Someone's misinformed.
Best Solution
posted on Oct 16, 2009
Very Helpful)
milten1
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 515 votes
it eis essentialy for emergency heat,
whatever way your wired your secondary heat source becomes your "emergency" heat.
It could not be economy, since its only called upon when your primary heat cannot handle the load. and thats only at start up. once your within a predeterminbed temp set, your secondary heat should drop out
sometimes they wire secondary, in direct conflict with primary as to not aloow the system to use both at the same time
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you sooooo much. You helped alot! " - jconstante31
Solution #2
Very Helpful)
hiltonjug
Rank: Guru
Rating: 92%, 215 votes
It stands for Emergency Heat. (Back up heat) . Normally you will find it on heat pumps. It's used manually when the compressor goes out on a heat pump. It's used automatically by the unit when it's so cold outside the heat pump can't keep up. This happens when there is not enough heat in the air to draw heat from. This happens at around 23 degrees. I hope this explains what emergency heat is and what it's used for.
Was this helpful?
Yes
No
Asker's Testimonial
" Thank you soooo much. You helped alot! " - jconstante31
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , CO
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
