Question about Canon PIXMA iP1600 Printer
Paper jam error message
My Pixma ip1600 won't print because of a paper jam message that keeps appearing. I can't see any paper (or piece) when I open the front cover, which is the only cover mentioned in the manual and the only one I can find that'll open. Numerous cycles of the "resume" button don't help. I tried the maintenance software and ran the option to clean the paper feed rollers, but this also ends in a paper jam message. I unplugged it and turned it upside down & shook it but nothing came out. Don't know if this is a true jam or a false message. I ran a few sheets of labels thru it shortly before the problem arose but an unaware of any labels coming off inside the machine- didn't notice any missing from the sheets after printing. I was only able to use it a few times after this. Anyone know how to get it apart, easily, to check the innards for any pieces of paper (or labels)? Or, a way to bypass the error message?
  • 1 more comment
  • badCanon Jan 09, 2008
    Thanks. I'll take your info & see if I can follow your guidance. I took the entire top cover off the other day, after removing 3 screws and a bit of pushing & prying where I found about 6 slots (& associated arrows pointing to them) scattered about the case. I still couldn't find a problem at that point but hadn't tried to analyze how the darned thing works. Now, with your instructions, I'll look at it again. I was ready to junk the thing. Canon offered me a coupon toward a new printer, but I'm not sure I want another Canon. I'd like to get this thing working, if only to use up the new cartridge I'd just put into it. I'll let you know how it works out. Thanks again.
  • badCanon Jan 11, 2008
    Bill Jr,
    Using your instructions, I attempted to identify the parts you referred to and wasn't able without more detailed description of size, location, shape, etc. However, after looking it over, I hooked it up to my computer again, still with the cover off. With some finagling, I was able to get a sheet to feed (by trying various placements of the sheet with respect to the little white plastic fingers that appear to hold the paper back from the feed rollers; I also had to experiment just a bit with the timing as to when to place the paper into the feed position). I repeated this process a few times till I noticed that the fingers were releasing on their own (such that they would allow a sheet to fall into the feed rollers). I then loaded a single sheet (this time before initiating the print command) and it fed and printed all on its own. I repeated this a few times and then ran a two-page print command; it again fed okay. I think it's okay now, probably until I put the cover back on; then it'll probably fail again- or maybe sooner. I followed up on the Canon offer for what they call the Canon Loyalty Program and found that the discount was a whopping 10% on a photo inkjet (don't know why a "photo" printer) or a stupendous 15% on an all-in-one inkjet. Don't think this is enough to buy my "loyalty" but I haven't ruled out Canon for a replacement.
  • kubo986 Nov 18, 2008
    I have a Canon PIXMA IP1600 which prints text and photographs okay when I select the Plain Paper setting but as soon as I change setting to Photo Paper Glossy I get an error message "paper jam" over and over again. I have tried this with full size 8-1/2x11" Photo Paper Glossy and also the smaller 4x6" Photo Paper Glossy and keep getting same error message. In the past, I was able to print photographs on both 4x6" and 8-1/2x11" Photo Paper Glossy with NO problems. Recently, installed new color printer cartridge...could this be the problem? Anyone else with this quirky problem?
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Posted on Jan 09, 2008
I solved my own problem with Canon 1600 that would repeatedly display "paper jam" message every time I tried to print on photo paper using High Glossy Plus setting. I just changed the paper setting to High Resolution and then the printer would allow me to print on photo paper. Results are acceptable but don't have the same crispness as photo setting.
K. Kubo
Posted on Nov 26, 2008
Wont print....it says paper jam....but not paper is jammed. what to do?
make sure you check the manual and open all inspection areas to remove any scrap paper, its normally the cause
Jul 21, 2014 | Canon PIXMA iP1600 Printer
How do you fix a paper feed problem in a Cannon iP1600
  1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
  2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
  3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
  4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
  5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
Good Luck!
Aug 23, 2010 | Canon PIXMA iP1600 Printer
My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Canon PIXMA iP1600 Printer
I keep getting a paper jam message but there is no paper jam. any idea????
There may be a piece of paper still stuck in the unit. If a paper jams in a printer, you should assemble the torn sheet and make sure all the pieces came out.
Forcing a jammed sheet out of a printer can damage the paper detect arm. This arm is usually near the platen (The roller the head prints against) to detect the paper as it passes.
Mar 28, 2010 | Canon PIXMA iP1600 Printer
Describe your Canon PIXMA iP1600 Printer Problem
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Mar 16, 2010 | Canon PIXMA iP1600 Printer
My Canon Pixma ip1600 thinks it has a paper jam but doesn't. So it won't print. Any suggestions? Any suggestions? Thanks, Tom
It may have a tiny piece of paper stuck in front of one of the senors. Try blowing out the machine with canned air or an air compressor.
May 01, 2009 | Canon PIXMA iP1600 Printer
Paper jammed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 10, 2009 | Canon PIXMA iP1600 Printer
I can`t solve paper jam.
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Dec 20, 2008 | Canon PIXMA iP1600 Printer
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
Paper Jam Error
Hello there
You may not see a paper jam.
Apr 14, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
602 people viewed this question
old marine
old marine
