Question about Apple iPod nano
Help with Nano Ipod
My son accidently disconnected the Ipod Nano 4MB with the connected logo still on screen and I have tried everything to get it to resinc including reloading applications of ITunes etc and cannot get it to turn off or reset - help a father struggling many hours after Christmas!
You have to press the "MENU" and "MIDDLE" button. Hold them for about 3 - 5 seconds. And it should slowly RESET. and your DONE!! =D
Posted on Dec 28, 2007
I have the white screen of death on my ipod nano 4gb
Welcome to Fixya!
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 23, 2011 | Apple iPod nano
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
Mi ipod nano 5th generation bacame blanck all white the screen and does not connect to the itunes or does not resset
Welcome to Fixya
1st option:
Feb 17, 2011 | Apple iPod nano 5th Generation
I have the white screen on my ipod nano 2nd gen i tried the reboot, restore, debug everything i cant see any logos text or anything i cracked my old screen ao i bought this put it in and bam white screen...
Hi.
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod. Try these steps:
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes
Nov 05, 2009 | Apple iPod nano 2nd Generation MP3 Player
My son has accidently put the screen lock on my daughters ipod nano & she can't remember the 4 digit code. Help!
1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
2. Open iTunes and sync the iPod as normal.
3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Oct 01, 2009 | Apple iPod nano
MY ipod nano 4GB silver has a white sreen and i cant see anything
my friend bought me a ipod for me ... it works nicely for nearly nine months but suddenly wen i connected my ipod with my handsfree everything was fine but all content was lost that i stored in ipod so i doubtly connected to my pc ..it shows everything that wat all previously stored in ipod even i can play but wen i disconnected my ipod again it shows no music no videos and no photos but the space was occupied .....
Jan 20, 2009 | Apple iPod nano
3rd gen nano 4gb
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
read more here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Jun 01, 2008 | Apple iPod nano
Apple iPod Nano 2gb
Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
Feb 20, 2008 | Apple iPod nano
IPod will not charge or download music from iTunes......help
Someone posted a similar problem on another thread and included a solution that worked for him/her. It worked for me as well, when I had the problem. For me, it was not an iTunes or iPod problem but a Windows Vista problem. I don't know what OS your son is running. I've copied the step-by-step instructions from the other thread into this thread for you. Give it a shot - good luck!
  1. Before manually placing the iPod into Disk Mode - verify that it has a charge, if not you need to either charge iPod before continuing or connect it to power. Either connect it to a high-powered USB port, or connect the iPod to the Power Adapter and pluf that into an electrical outlet..
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again. Just slide back and forth. )
  5. Disconnect iPod from the power adapter and connect it to your computer; the screen on the iPod will change and say "Do not disconnect"
Feb 12, 2008 | Apple iPod nano
Ipod nano security code
to reset switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
Feb 10, 2008 | Apple iPod nano
Apple iPod nano Logo
27 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
