Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | Abbreviation def...
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Abbreviation definitions.
By jconstante31 on Oct 16, 2009
Hi again. Concerning AC/Heating units... for heating, what exactly does EM abbreviate? What about AUX? My landlord is inquiring.
Comments:
Oct 16, 2009
- I thought EM meant Economy Mode?
Oct 16, 2009
- I thought EM stood for Economy Heat?
Oct 16, 2009
- I though EM meant Economy Heat?
Oct 16, 2009
Oct 16, 2009
- ECONOMY MODE or EMERGENCY MODE?
Clarification Request
Posted by bobfreengel on Oct 16, 2009
Em: Emergency heat Aux stands for auxiliary, as in auxiliary heat or fan.
Best Solution
posted on Oct 16, 2009
Very Helpful)
bobfreengel
Rank: Wiz
Rating: 88%, 12 votes
Simply put, all Heat Pumps in northern climates [below 35 degrees] need a supplemental heating source. Usually it is in the form of electric resistance heating. This is an all-electric Heat Pump. It can be a gas, oil, or hot-water back-up system as well. The supplemental heat is also referred to as "second-stage" or "back-up" heating, "first-stage" being the Heat Pump only. The supplemental heat is also what is used as the Emergency Heat.
  1. When switching to Emergency Heat, the red indicator light will go on. And it will stay on until you stop using the Emergency Heat. This just lets you know you are in "emergency mode." On a call for heat, no signal will be sent to the outdoor Heat Pump. Only the indoor unit and the back-up heat will run.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thank you. Now I understand clearer. You the man! " - jconstante31
Solution #2
Very Helpful)
lccjester
Rank: Guru
Rating: 97%, 491 votes
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Was this helpful?
Yes
No
Asker's Testimonial
" Awesome! I thought I'd never find these things out but you proved me wrong. Thanks for caring. " - jconstante31
Solution #3
Very Helpful)
muebe
Rank: Guru
Rating: 90%, 244 votes
If your referring to the "em" and "aux" heat on the thermostat...Those are used on heat pump systems. "EM" is for emergency heat and "aux" is for auxillary heating. Is your heating system a heat pump,hydronics, or gas?
Comments:
Oct 16, 2009
- I have never heard of "EM" satnding for economy mode... Here is what I copied from another website http://www.hannabery.com/quest2.shtml about "EMERGENCY HEAT" . That is why I asked if you had a heat pump or hydronics.
The Emergency Heat switch on a Heat Pump thermostat confuses many people. The fact of the matter is that most people don't seem to understand exactly what Emergency Heat is and when they need to use it. Many people think that Heat Pumps don't work in cold weather and they are supposed to use the emergency heat whenever it gets really cold... Wrong!
What is Emergency Heat?
Simply put, all Heat Pumps in northern climates [below 35 degrees] need a supplemental heating source. Usually it is in the form of electric resistance heating. This is an all-electric Heat Pump. It can be a gas, oil, or hot-water back-up system as well. The supplemental heat is also referred to as "second-stage" or "back-up" heating, "first-stage" being the Heat Pump only. The supplemental heat is also what is used as the Emergency Heat. Different systems have different ways of determining when the second-stage comes on to assist the heat pump but it is always done automatically. So the two stages will work together in the colder months and it is not necessary to switch your thermostat to Emergency Heat. Now we know what supplemental heat is and that it is also used for Emergency Heat. So when do I actually use the Emergency Heat?
As the name implies, it is only used in emergency situations. It is used when there is something wrong with first-stage heating [the Heat Pump itself]. In other words, if you notice your house is cold and it isn't heating properly and you went outside and noticed that a tree fell and crushed your heat pump, that would be a good time to switch to Emergency Heat. Or if you look at the picture below; this Heat Pump turned into a block of ice due to a malfunction. At this point, it isn't capable of providing any heat. Simply turn the thermostat to Emergency Heat and call for service.
Oct 16, 2009
- EM is EMERGENCY MODE. It cannot be ECONOMY MODE if it is using additonal heating to speed up the warm up of the home. But it is used with HEAT PUMP systems so if you unit is NOT A HEAT PUMP then the thermostat will still work but those functions on the thermostat WILL NOT.
Was this helpful?
Yes
No
Asker's Testimonial
" Thank you for your input sir. You and a fellow guru helped me narrow it down. I needed that. Have a great weekend! " - jconstante31
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
when this happens i open up the unit outside & there is only one test light flassing. i have to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
