Question about Panasonic PV-L680 VHS-C Analog Camcorder
Dew detected The camcorder powers off due to the following message "Warning Dew Detected". The camera does not have any moisture condensation in it, so we can not figure out what to do. Please advise if this has happend to someone else, and how did the solve the problem.
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Posted on Jan 04, 2008
When startup show the messaje "WARNING DEW DETECTED" and 5 seconds later shutdown
Dew warning is normal and means condensation has been detected the camera. Usually this happens when you take the camera from a warm room to a cold external place or vice versa. Wait for about an hour or so for the camera to acclimatise.
Apr 27, 2011 | Panasonic PV-L550 VHS-C Analog Camcorder
Dew detected for the PL-L750
warm it up put next to heater not to hot.. don`t leave camera in cold
May 15, 2010 | Panasonic PV-L750 Camcorder
Message in my camcorder says condensation detected how do i clear screen
yes. dew sensor problem. open all doors and panels. get hair dryer and blow in and around the unit for 5 minutes with batteries taken out of unit
Nov 15, 2009 | Canon ZR20 Mini DV Digital Camcorder
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Aug 01, 2009 | Panasonic PV-GS300 Mini DV Digital...
Dew Detected message
i have dew detected all the time that shuts down my camera
Dec 11, 2008 | Quasar VM-L459 Camcorder
When the camera's circuits detect condensation on the tape heads, this message is shown and the camera shuts down. This is to prevent damage to tapes, that could stick to the damp head.  It is recommended to leave the camera in a warm and dry place until sufficient time has elapsed for the condensation to evaporate. This may be several hours. Do not leave the camera anywhere too warm that is likely to damage it, like on a stove or radiator.  This issue is commonly caused by moving the camera from the cold outdoors, into the warmth of indoors. If the symptoms persist, the head may be dirty. try a head cleaner cassette, or failing that, return for service.
Moisture detected
Take the battery pack off and hit it (not too hard) with the palm of your hand. It SOUNDS CRAZY but my own camcorder had the exact same issue and all it took was one hit- put the battery back on then powered it up- VIOLA- it works! I am not kidding, try it. You'll save LOTS of $$$$$. This is NOT a joke.
Sep 07, 2008 | Video Cameras
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Moisture detected
disconect the batery and conect again several times. wait until it shut off and repeat again. it will work in minutes.
Feb 27, 2007 | Quasar VM-L459 Camcorder
Condensation
When pouring a chilled beverage into a glass, water droplets may form on the surface of the glass. This happens because the air around the glass is rapidly cooled down, and moisture in the air adheres to the surface of the glass. This phenomenon is called condensation. This kind of condensation may also occur with camcorders. If you continue to use the camcorder with condensation on it, it could damage the camcorder. Condensation may form on the camcorder in the following cases: (1) When being moved from a cold place to a warm place (2) When being used in a rapidly-heated cold room (3) When being used in a humid room (4) When being moved from an air-conditioned room to a warm, humid place When condensation occurs: The camcorder stops operating automatically after its power lamp flashes. The warning message "CONDENSATION HAS BEEN DETECTED" appears and the condensation-warning icon below starts flashing. Condensation-warning icon If a cassette is loaded, the warning message "CONDENSATION HAS BEEN DETECTED" and "REMOVE THE CASSETTE" appear and the cassette-warning icon starts flashing. Cassette-warning icon If a cassette is loaded in the camcorder, remove the cassette immediately and leave the cassette compartment open. If condensation is detected, the POWER switch and cassette-removing switch will be activated. Leaving the cassette in the camcorder may damage the tape. A cassette should not be loaded into the camcorder when condensation is detected. How to avoid condensation Unload the cassette and place the camcorder in an airtight plastic bag when moving to locations where temperatures vary. Allow time for the camcorder to adjust to temperature changes slowly before removing it from the bag. Resuming use Allow at least one hour before resuming use; more time may be required for heavier condensation. When condensation has been eliminated, turn the camcorder on. After the condensation-warning icon stops flashing, wait one hour before resuming use.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Panasonic PV-L680 VHS-C Analog Camcorder Logo
223 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
