Carrier 38CKC060 Air Conditioner
Problem for Carrier 38CKC060 Air Conditioner
How much should I expect to pay to replace the
By pomukai on Oct 16, 2009
How much should I expect to pay to replace the outside unit with a similar unit? The refrigerate is leaking out from a crack in the weld joint.
Solution #1
posted on Oct 16, 2009
Not Rated)
hiltonjug
Rank: Guru
Rating: 92%, 219 votes
Is the joint where the crack is copper to copper or copper to aluminum? With this being a Carrier, it could be either. If copper to copper, it can be re-welded (repaired) with no problem. If copper to aluminum, there is an epoxy on the market that will repair it if it's not to big. If it's to large of a leak, you will indeed have to replace it. A word of advice. I you do replace it, don't let the contractor sale you another aluminum coil unit.
I'm not sure where you are located so this price may be more or less. Although it should be in the ball park.
It looks like what you have is a 5 ton unit by the model number but I'm not sure if it's a heat pump or not. Plus I'm not sure how old it is so I'll give you a price based on these facts.
Your unit
  1. being a 5 ton unit
  2. an older unit with R22 Freon
  3. Being straight air (Not a Heat Pump)
If your contractor will replace the unit with one with R22. (No more made after 01/01/2010.) I would charge around $2800. If the contractor can't find or will not look for a R22 replacement they will have to replace not only the outside unit but also the inside coil. For this I would charge around $3800. To replace the complete system with a 13 SEER ( R410A unit) I would charge around $5200. The difference in prices I gave is if you wanted a YORK or a Goodman. A Goodman will be around $1000 less than a YORK. The most expensive brand on the market is a TRANE. I'm a YORK dealer and to be honest with you, a Goodman is just as good and does the same thing as any of the other brands. They also offer from a 13 SEER to a 16 SEER. YORK offers up to an 18 SEER as well as TRANE. If your unit is not more than 8 years old, I would only replace the outside unit myself but I assure you that the salesman will advise you to replace the whole unit. This is what they get paid for and that's were the company stands to make the largest profit. There are companies in my area that will tell customers that coils can't be repaired. That once they leak, they have to be replaced or at least the coil.
Just be smart and do not let the service company sale you something you do not need.Good luck. Sorry to be so lengthy. I'm just trying to give you as much information as I can and I hope it helps you make a wise decision, not a costly one.
Was this helpful?
Yes
No
Solution #2
Not Rated)
milten1
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 523 votes
i would say less than 3000, '
for a condensor replacement only
figure in the cost of the unit plus 2-5 hours of labor
and then of coarse the refrigerant
ive done this exact job several times
and the highest final bill
just about 2200
but it depends on the markup in your area
on the unit, refrigerant, new copper,
Was this helpful?
Yes
No
Popular Solutions for Carrier 38CKC060 Air
Questions and Unsolved Problems for Carrier 38CKC060 Air
Do you recommend Carrier 38CKC060 Air Conditioner?
Answer
Answer
i have a pioneer air con ducted model no:ps11. i neen the cap sizes as the old ones dont have a... (More)
Answer
Hi, My Fujitsu airconditioner turns on by remote but it doesnt blow cold air.Its a dual hook up... (More)
Answer
E1 is flashing on comfort zone ii. Tech tried switching our thermostat--did not work. I think it is... (More)
Answer
unit starts up again after few minutes then shuts down again with e3 displayed. Noted at one time,... (More)
Answer
I have a carrier ducted unit in my home and it keeps flashing E1. What does this mean?.
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
