Question about Philips 55PP9401 55" Rear Projection Television
Inside the cabinet projected on the screen?
I have a Philips 55PP9401. It has a beautiful picture....While on, it looks like a cob web with some dust on it is being projected onto the screen.
Is this possible and if so, can it be remedied easily?
Its a spideweb behind the screen. i had the same problem, take the back off (unpluged) and spray them out whith a can of compressed air. i thought mine was screen damage for a long time till i saw the spider walking on the screen from inside.
Posted on Dec 31, 2007
    Sergeant:
    Champion:
  • 231 Answers
Well . there are 4 things that can cause this..
1= the outer screens could be dirty.clean with screen protector cleaner.Spray on cloth and not on outer screens.
2= outside lenses of picture tubes could be dirty.Unit can be opened .Outside lenses can be cleaned with a lens cloth .Do not use paper towels or cotton as this my scratch surfaces of lenses.
3= inside of picture tubes could be dirty.This should be done by a repair shop only(dirty coolant inside tubes)
Posted on Dec 28, 2007
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
51" Philips Projection Wide Screen. Want to know
Almost all the Philips projection sets have a large black plastic shroud on the top half of the back of the set----it can be removed--most of these sets use torks type screws (star shaped).
With the upper part on the back removed you will find the mirror is suspended---do not try to clean it--it is film like handy wrap and will not need cleaning.
I use a swiffer type duster to reach inside the set to remove any spider webs etc, If dead insects or dirt inside the screen use a very soft cloth with water (just dampen the cloth slightly)
Usually you are seeing spider or cob webs and the duster will get them all--DO NOT APPLY FORCE IF YOU WIPE THE INSIDE OF THE SCREEN AS IT IS EASY TO SCRATCH IT!
If this information helped you, rate this solution as I do this here for free.
If you have questions make a comment here and I will do my best to answer them.
REGARDS, SD TECH
Aug 18, 2010 | Philips Magnavox 27MS343S 27" TV
I have cob webs on the inside of screen. How do I open up to clean them out?
Unplug the TV. Take the back off. Using a broom or duster with a long handle, get the cob web inside the TV. Make it sure not to push the screen out. Good luck!
Apr 10, 2010 | Sony KP-51WS510 51" Rear Projection...
My screen seems to be very blurry like it was dipped in baby oil
You may have mineral deposits on the inside of your screen or if it is a projection set then the projection lenes and or mirror has mineral deposits on it and or dust and or cob webs obscurring the image.
Oct 04, 2009 | Philips Magnavox 9P6034C 60" Rear...
Problem with HDTV on my Philips 55PP9401.
it is not reccommended for game console to be played on a projection t.v because projection tv's have three color bulbs in them and the conversion is different and if it happens to work it has been known to have burn the games image in the screen after awhile.. usually the store doesn't tell youthat unless you ask them about playing game consoles on a projection tv
Dec 01, 2008 | Philips 55PP9401 55" Rear Projection...
Lost remote / convergance problem
u can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
Oct 07, 2008 | Philips 55PP9401 55" Rear Projection...
Cob web
The cob web is likely to be on the other side of the screen. I undid the back cover and dusted the screen from the inside. I also sprayed pesticide inside the TV (wood and corners only!)
Mar 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 55" rear projection screen
you need to take off your back cover take a can of air you can buy at electronics store and blow off the projector it probably has dust on it
Feb 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Cobwebbs between the screen and the screen protector
Hi pykeman,
I have successfully used a feather duster taped to a vacuum cleaner extension tube with duct tape. Remove the back panel of your projection television, then remove the the rectangular panel near the top over the chassis where the cabinet exposes the inside screen area. You will see the red, green, and blue CRT lenses. Insert the feather duster through this rectangular opening and sweep your cob webs away from the screen. Works for me every time.
Regards,
MyTvGuy
Jan 19, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
