Question about HP LaserJet 3015 All-In-One Printer
Hp LaserJet 3015 Printer.
When I print out copies they print out as usual, but each sheet has a full length vertical line about 1 1/2 lines in from the left hand edge.
How do I eliminate this vertical line? Its not static.
Thank You Kyle Robertson
whitehse@log.on.ca
  • battlese Apr 01, 2008
    Same problem here and there are plastic pieces coming out. Would it be the fuser? From what I've found the fuser is about 1/2 the original cost of the printer.
  • Anonymous Apr 14, 2008
    I have a thin black stright line printing on the paper. Any suggestion on what is causing this and how to stop it from happening again?
  • 417 Answers
Is it wavy? if so then it is either the toner cartridge or the fuser unit (heat section) I would go for the fuser unit as the hot roller that makes the toner stick to the paper is only a plastic film. Have you noticed any gray pieces of plastic coming out?
Hope this help you and you can get these machines repaired also please rate me
Cheers J
Posted on Dec 31, 2007
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
Multifunction HPLASERJET 3015: when I start copying a document will always print a black vertical line on the right of the page
Advisable for users & tech guys: Lift document feeder unit clean "scan head" glass with glass cleaner, check..
Sep 24, 2011 | HP LaserJet 3015 All-In-One Printer
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
My hp laserjet 3015 printer is printing all my pages in just one page
Check your printer driver. The printer is doing what the driver is telling it to do. Check the "printing preferences" button. Set it up to print "1 page per sheet".
Oct 21, 2010 | HP LaserJet 3015 All-In-One Printer
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when...
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Aug 24, 2010 | HP LaserJet 3015 All-In-One Printer
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
White line to left of every page that is printed/copied. HP LaserJet 3015
you have to clean or replace your scan unit, call the technician
Apr 07, 2010 | HP LaserJet 3015 All-In-One Printer
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
LaserJet 3015
The line was not a crack in the glass-as I thought it might be.
However, I cleaned the two sides of glass with piece of clean kitchen roll and it is clear now!
Thanks
J Taylor
Sep 10, 2008 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
224 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
