Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Elite Trio . Very hot case.
There is clearance on all sides of appliance, grater than those specd. however the exterior surface of the case on each side of the freezer door and between the freezer and refer. is extremly hot. This has significantly impacted the performance of the freezer.
    Problem Solver:
  • 10 Answers
Make sure your condenser coils are clean.If they are dirty it will not only effect the cooling but may cause higher temperature around the casing of the box.
Posted on Dec 28, 2007
Elite Trio. What caused it to die suddenly after only six years?
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
CPSC Maytag Corporation Announce Recall of Kenmore Elite Brand TRIO Model...
Info on Recalled LG and Kenmore Elite Trio Three Door Refrigerators
Oct 01, 2015 | Kenmore Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
My kenmore Elite Trio lights didn't go off, it burned the light assembly in the refrigerator part. The bulbs turned dark and it melted the assembly a bit, the cover won't stay on. can I install a whole...
This will possibly fall in the class of models that were under recall. My advice is to contact Sears and the CONSUMER ALERT Remove your lighyt bulbs and prepare for a disgusting attempt for settling this. I am not telling you you this for any good rate or a bad rate. LG and Maytag made these for Sears and the name then changed to Kenmore Elite Trio. I would like you to visit my web page and do a little reading of our posting's here at Fixya over the past couple years. Wish I had a solution but feel it is my responsibility to inform you. Thank You for Understanding, Sea Breeze
Nov 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Elite trio
Hello bigmikeegator
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
Thank you,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the solution?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
