Toshiba 57H82 57 in. Rear Projection Television
Problem for Toshiba 57H82 57 in. Rear Projection Television
Picture has alot of lines in it went you turn it
By dennisavon on Oct 16, 2009
picture has alot of lines in it went you turn it on takes 10 to 15 min. to clear up
Best Solution
posted on Oct 16, 2009
Very Helpful)
SD Tech
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 97%, 1161 votes
I do not have good news for you---if it has lines etc and clears up after several minutes--usually as it gets worse it takes longer and longer, you have a bad HYPER board--very common in these sets--board is now only available on an exchange basis--means board has to be removed and sent out for rebuild/repair.
Toshiba no longer sells this part--I just helped someone else here yesterday with a slightly different model with the same problem--he was very savvy and I sent him a photo of the board and the 10 surface mounted caps that go bad--not a job for most do it yourself people--what goes bad here are several surface mounted caps on the Hyper board--they dry out from the heat and age...
To make matters worse--most of these boards are soldered in--there is a national company who can repair/rebuild the board in your model: part number for the rebuilt board is: 23148024
This board costs about 220 dollars not counting labor to get it our and shipping etc.
The person I stepped through the repair did it himself for about 25 dollars in parts cost.
The company that does this kind of repair is PTS electronics
Let me know if you have any questions or need advice--I am here to help people--I cannot always give good news but I would bet you have a bad Hyper board.
REGARDS, SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Toshiba 57H82 57 in. Rear
Questions and Unsolved Problems for Toshiba 57H82 57 in. Rear
Do you recommend Toshiba 57H82 57 in. Rear Projection Television?
Answer
Answer
can you change the picture size without a remote on a toshiba57h84r
Answer
tv will not turn on has worked for years and suddenly does not. think it must be power unit but... (More)
Answer
My Toshiba 57H82 always cuts the picture short on the top or bottom. None of the Pic Size menus... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
