ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new updates. now it doesnt respond after 5 hrs.only led light of power nd on off switch shows up..wat 2 do?
try to boot in safe mode(press F8 repeatedly...when the computer starts).if this work...try to uninstall those updates...may be a system restore....if this not work...hit del or F2 to enter in bios and disable options like system bios caching or shadowing....if all this things not work...last solution is to reinstall win. change boot options in bios to boot from cd first ...and ...next...next.....
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5735 PC Notebook
Acer 5735. There is no help section file on the recovery discs and they do not run automatically How...
(More)
Acer 5735. There is no help section file on the recovery discs and they do not run automatically How is the recovery carried out?
Keyboard does not stick down at the rear middle point, and battery lock will not lock as slide...
(More)
Keyboard does not stick down at the rear middle point, and battery lock will not lock as slide holding battery in place will not move all of the way to lock without damaging the battery, or lifting it out of the case and disconnecting it.
I have an Acer Aspire 5735 Laptop......... Every time I try to turn it on/boot it up it fails to and...
(More)
I have an Acer Aspire 5735 Laptop......... Every time I try to turn it on/boot it up it fails to and hangs, showing just a flashing dos-style cursor in the top left of the screen. If I turn it off and try again, it ALWAYS boots straight up second time round. Can anyone please tell me (simple terms please!:-)) why it's doing this? Thanks in Advance.
Acer Aspire 5735 DVD drive does not work. Indicator light flickers a couple of times but does not...
(More)
Acer Aspire 5735 DVD drive does not work. Indicator light flickers a couple of times but does not recognise the CD disk. Can anyone help.?
