Question about Dell Dimension 2300 PC Desktop
Computer turns on, but there is no display on monitor.
My monitor stays completely black when I turn on the computer. I switched out the monitor with my other monitor (which works perfectly on my other computer) and had the same problem--black screen. Is the video card bad? I believe the video is built-in. Can I buy a video card and put it in one of the two open PCI slots?
  • westman2 Dec 28, 2007
    I will buy a new video card and see if it works. Thanks for the quick response.
Im having the exact same problem it takes like 20 power ups for my video to display!! When it does my games work fine so i mean ...it cant be my video card its running DX10 games (EVGA8800)
WHAT CAN CAUSE NO SIGNAL INPUT RIGH ON BOOT (CANT EVEN SEE BIOS)
Posted on Jan 02, 2008
    Genius:
  • 1,601 Answers
The builtin video card is probably bad. Yes, you can get a PCI video card.
Posted on Dec 28, 2007
I have a 19" cmv
How old is it? If it still under warranty get it repaired, it sounds like the switch is gone or the energy saving s/w inside is bad and is not detecting when/when not to turn the display on/off.
May 22, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
When monitor is turned on, it flickers 3 times and then goes blank
Does the computer stay on or switch off?
If the computer stays on and the monitor completely switches off then it's a monitor power problem.
Make sure all connections are securely connected.
If the computer also completely switches off then it's more likely to be a computer problem.
If it's a monitor problem then the monitor will have to go to a monitor repair shop.
If the box does switch off then let us know to continue to troubleshoot.
Aug 18, 2009 | Gateway Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
The screen turns black and stays like that
Normally it's because the resolution is set too high for the monitor. This has happened to me when I switch a computer from a flat screen to a old "biggy-size" monitor.
try rebooting the computer and BEFORE you see the windows splash screen, start pushing the F8 key...this should bring up a menu...select VGA Mode...it won't be pretty, but once you're in..right click on the desktop and change the solution (try 800x600). restart the machine...that should work.
-SuperDale
May 05, 2009 | Apple Computers & Internet
The monitor turns black immediately after power cycle
i think it can be the capacitor problem, open monitor an look for swollen capacitors. if you will find them swollen or mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:IT;} @page Section1 {size:8.5in 11.0in; margin:56.7pt 42.5pt 56.7pt 85.05pt; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} loosing the electrolyte, signs of burn, change them
Apr 12, 2009 | LG 22" FLATRON LCD Monitor
No pic on screen
Double check all of your connections. It appears the video cable is not plugged in completely. Try another monitor if possible to see if the computer is actually outputting video.
Jan 03, 2009 | Dell Computers & Internet
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell Dimension 2300 PC Desktop Logo
160 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
