Question about Princeton Digital VL1918 Monitor
Keeps losing resolution
Set to recommended resolution but need to do it every time we switch users or turn computer on
Try updating you're display adapter driver. Go to my computer, right click on that icon. Click on properties. Go to hardware tab, click on device manager. A window will open. Open up the display adapter tab, right click on you're display adapter and try to update driver. Then follow the wizard. That worked for me.
Posted on Jan 09, 2008
Appear image when open the switch and then lose
Dear user ,when starting the PC again keep pressing F8 if using windows OS ,Then select the option safe mode .after getting to the desktop ,right click on the desktop the select properties and lower the screen resolution to a lower setting like 800X600 It will work
Aug 13, 2013 | Dell E173FP 17" LCD Monitor
Can't get full resolution without losing taskbar
try setting to the desired setting then go to the top task bar click on the icon that has one square on another as that reduces the screen size
Jul 08, 2017 | Samsung SyncMaster 932GW LCD Monitor
Not optimum mode recommended mode 1280x1024 60hz
It is showing the message because your PC video resolution is not set to the native resolution of this monitor, you may able to turn off the warnig in the onscreen user menu setup.
Resolution: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
I would recommend you to reset your PC video resolution to the native resolution for best picture.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 18, 2011 | Samsung SyncMaster 710N 17 in. Flat Panel...
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
When switching ford one user to another a input not supported
You get input not supported because the another user had set the video resolution too high for the monitor to display. Try looking into the resolution setting.
Mar 26, 2010 | Computers & Internet
After restarting for an automatic update my desktop was in a "default" arrangement and the resolution was changed. I attempted to change it back but must have set it to the wrong res, cus the screen went...
Yes video drivers need to be updated then go back where you went to change the resolution and click keep this resolution I think you mistakenly told not to accept it this happens.
Please leave postive feedback and ratings today
Oct 15, 2009 | Samsung SyncMaster 512N 15" Flat Panel LCD...
KVM Switch
The reason why this is happening is because the notebook keeps on loosing it's resolution and the GCS62 can't remember what's the resolution set to the notebook.
To resolve this problem, please follow the steps below:
1. Disconnect the tower from the GCS62 and leave the problem computer (notebook)still connected to the KVM switch.
2. Set your desired resolution (ex. 1280x768) to the notebook.
3. Restart the notebook while it's connected to the KVM switch.
4. The GCS62 will remember the resolution you set to the computer.
5. After rebooting the notebook, you may now reconnect the other computer and try to toggle to see if you will get the same problem.
But doing these steps should resolve the issue.
Mar 20, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Input setting
When you turn off the set, are you turning it off by running the power through a cable or satellite box? If you are shutting down the set from the AC mains side the set can lose all of its user set-up. In most TV models, the main power supply must have the AC mains connected.
The power supply goes in to a standby mode when the TV is turned off by its own power switch (not by the AC mains). The supply puts out enough power to keep the uPC and the user memory active.
If the set is properly turned off and it is losing its user set-up, it is possible that there is a fault in part of the uPC circuits. Depending on the model of set, there may be a lithium battery, or memory capacitor, or an EEPROM for keeping the user set-up memory.
Jerry G.
Apr 18, 2008 | Polaroid FLM-2011 Television
Resolution
use 1280 x .. range resolutions for 17" monitors and 800x ... range resolutions for 15' monitors . dont hear to recommended resolutions
Dec 04, 2007 | Gateway FPD2275W LCD Monitor
Oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
Princeton Digital VL1918 Monitor Logo
111 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
