Question about Brother MFC-8840D All-In-One Laser Printer
Error Msg: PAPER JAM in Brother MFC-8840D
At bottom, scrolling instructions say "Open cover, then remove jammed paper." I've done this and there is no jammed paper left, but error msg remains -- even after turning power on and off! Status LED remains red.
  • 2 more comments
  • Anonymous Oct 11, 2008
    i have a paper stuck in the back and won't remove at all when off or even on
  • Anonymous Jan 22, 2009
    I have the same problem; error indicate ''paper jam" no paper inside the machine.
  • gmctek Feb 04, 2009
    My MFC-8840D also shows paper jammed, and has no paper stuck anywhere!!!
  • audibev Feb 12, 2009
    Out of nowhere our printer decided that it had a paper jam, and that we needed to open the cover and remove the paper jam. Well I have done that and their is no paper jam. I have removed and open everything to see if there was paper stuck anywhere else and there isn't. I have also turned the printer On and Off and it still shows that message. It is making it unpossible to do print, fax, or copy anything. Any input would be so appreciated! Thank you!!!
  • Brother Master
  • 1,113 Answers
One of the jam switchs is stuck down or paper concertina in fuser assy
Posted on Dec 28, 2007
Had paper jam which have cleared. Getting support code 6001 saying turn off and restart which we have done but still keeps coming up with same error
The 6001 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
Aug 24, 2016 | Office Equipment & Supplies
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Hi I had a paper jam in my MFC 8820d - I removed the cover and removed the paper but I still get a Paper Jam error msg. I powered down the machine and turned back on - still same error msg. I have removed...
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Sep 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
When the machine dont start fault error 102-353
Solution: Remove the Paper Jam in the Duplex Automatic Document Feeder (DADF) Top Left Cover bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. Lift up the handle on the Left Cover of the DADF until the cover comes to a stop.
    NOTE: An inside cover will also raise with the Left Cover as the two covers are interlocked.
  2. Gently open the covers.
  3. Remove any paper that may be jammed. Check for obstructions in the DADF area including jammed originals, paper fragments, paper clips or staples.
  4. Check for obstructions in the DADF paper sensor area, small paper fragments, paper clips or staples may get caught there.
  5. Clean the DADF rollers with a damp cloth.
  6. Close the Left Cover on the DADF until you hear it click into place.
  7. Raise the DADF, remove all the originals, and then lower the DADF.
  8. Make sure your originals are not torn, wrinkled, or folded. Load your originals again following the instructions on the Touch Screen.
    NOTE: Originals that have already been scanned will automatically be skipped, and scanning will resume from the previous document sheet.
  9. Torn, wrinkled, or folded originals may cause paper jams and damage. Place the originals directly on the Document Glass to make new originals that can be scanned using the DADF.
Dec 29, 2008 | Xerox DocuColor 1632 Laser Printer
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8840D All-In-One Laser Printer Logo
977 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
