Question about Fuji FinePix A350 Digital Camera
Stuck on standby
No matter what I try, new batteries, pushing buttons the camera reads standby with a pic of a movie camera help!!
  • lindyhoffman Dec 28, 2007
    even sliding the button to the right does not change or fix the problem( I had already tried that)andI tried again but no results.
  • dvdmack Jan 06, 2008
    stuck in video mode even when the setting button is pushed to the far right (camera mode). new batteries, different settings, cussing, etc. are not working. is the conclusion simply that the camera sucks?
  • 667 Answers
The sliding button above the LCD display has three settings. You need to slide the button to the right, A camera icon for taking pictures, a movie camera in the middle and the green arrow on the left to view pictures and movies taken
Posted on Dec 28, 2007
  • Kevin Pettit
    Kevin Pettit Dec 28, 2007
    I've seen that before. The contacts on the backside of the button have come undone from the switch. It is repairable.
No sound from new Pioneer DVD player
try resetting defaults
Place DVD player in standby mode
Push in the stop button on the hardware unit and keep pushed in
Push in Standby button on the remote provide while doing the above
Then put into standby mode again insert your DVD and see if it changes.
All Happiness
Apr 08, 2010 | Pioneer DV-333 DVD Player
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Camera on Standby?
There's a menu in Options to continue/resume using the camera when it's on standby.
Go into the menu and reset the phone to original settings, (You might loose all your data). Or try switching the phone off and taking the battery out then leaving the phone alone for 1 hour.
Mar 11, 2008 | Nokia 6300 Cellular Phone
My camera is stuck on movie mode
It appears that the software crashed. Take the batteries and the memory card out, press the on/off button as if you are turning the camera on (this is to drain any residual power in the camera). Leave it for a few moments (10-20 seconds) then put the batteries and the card back in and restart the camera. If the camera has a reset button or reset hole try this too. Good luck.
Jan 24, 2008 | Fuji FinePix F20 Digital Camera
Stuck on movie standby
The ribbon cable for the top switches has come loose.Undo the four screws holding the LCD screen (two are special--I used the corner of a small flat screwdiver), then gently prise the camera apart and try not to dissconnect the ribbon cable for the menu buttons --it's a pain to get back on again.
Gently ease the ribbon cable for the top switches further into the socket and all shout be well---if it is hard to move flip open the black locking flap on the socket
Jan 05, 2008 | Fuji FinePix F20 Digital Camera
UNIQUE PROBLEM: Camera stuck on Movie mode
It's a small world. I have an Ixus V2 on the bench with exactly the same problem. The sliding button on the camera mates with a switch soldered to a flat ribbon cable inside the camera. There are two small teeth which move the internal switch left ot right. What's happened is one of those plastic teeth has snapped off the external part and now it can't push the switch anywhere. If you pulled the camera apart you could push the switch into either record or review but that's it. It will stay in either of those positions. Which is a bummer. The only way to fix it is to buy the complete flat cable ribbon with switch attached and boy it's a long cable. Except for sending it away for repairs (expensive) buy a damaged one on Ebay and do a transplant. Just make sure it's suffering the same fault.
Jul 19, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Lens distorded
hi NO, the battry cannot have make this occur!! its sound like the memory card is retired! borrow 1 from anybody just to see if it works and then buy a new 1 is the image blurred when you download the pic to the computer? if not - its only the LCD how distorded the pic - it dosent matter if soo your lens is bad - it needs a fix good luck
Apr 19, 2006 | Nikon Coolpix 5700 Digital Camera
Fuji FinePix A350 Digital Camera Logo
80 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
