Heat Pump Not Performing up to par...
I have a Intertherm T3BC-060K heat pump and it is just not performing as before. I have cleaned the air handler and replaced the filters. I have also cleaned the outside unit and used an air hose to blow out the bugs and debris. I began to notice the system is coming on and running continuously even with the moderate temperatures we have been having. The air output is cooler than normal and I also noticed the unit outside is forming ice around where the pipes are located in the gridwork. Any ideas??
Thanks.
  • 236 Answers
While is newly operating check the unit data ( suction press., discharge press., current reading be sure that no ice formation in this testing.) If every thing is normal then you have to focus in the unit control.
- check for out of range thermostat.
- check for stuck up magnetic contactor or relay.
- if it is digital check for out of range sensor or defective control.
Posted on Dec 30, 2007
    Sergeant:
  • 288 Answers
This sounds like a small freon leak. If you have a low pressure cut out switch, it should cut the compressor off before it gets too low. If you have a lot of ice on the outside coil, then maybe the defrost board or the sensor has went bad. But because you said it is running continuously, I think its low on freon. Unless you own a set of gauges for this equipment, call a pro.
Posted on Dec 28, 2007
How to remove Heat strips from intertherm furnace to make an air handler? Wiring schematics
WHAT??? Removing heat strips does not make an air handler. Air handlers have heat strips, please explain
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Intertherm Heating & Cooling
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
I have a older Intertherm heat pump that has quit heating but still cools alright does anyone have any suggestions what could be wrong??
Check your reversing valve, When you set your thermostat for heat the reversing valve circulates the heated freon through the air handler instead of the cooled freon. The valve is called many things but it reverses the flow of freon See http://www.google.com/images?hl=&q=heat+pump+schematic&rlz=1B3GGGL_enUS329US330&um=1&ie=UTF-8&source=univ&ei=npcOTfLEPMO88ga4poDGBQ&sa=X&oi=image_result_group&ct=title&resnum=2&ved=0CC4QsAQwAQ&biw=1024&bih=576 and look at the different schematics
Dec 19, 2010 | Intertherm P3RA-036K Air Conditioner
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
My cooling and heat pump quit working and the fan outside does not come on. If you push in the contactor in the fan comes on and sounds like the compasator does to.
Check the voltage at the contactor where the 24 vac connects to the coil for the contactor so you can see if it is making it that far. It will be 2 smaller wires that are not connected to the 240 vac. Let me know if you have 24 vac there. The thermostat will have to be calling for air for the 24 vac to be present. let me know what you find.
May 05, 2010 | Intertherm P3RA-060K Air Conditioner
Changing Air Filter
In general terms an electric unit uses a 20 x 20 x 1 filter and a gas system uses a 20 x 25 x 1 filter. If the return filter is somewhere other than at the unit, it will very greatly in size. Its the descretion of the installer as to what size filter they choose to install.
Apr 07, 2009 | Intertherm P3RA-030K Air Conditioner
Intertherm central unit heating side not working right
I am assuming this is a heat pump? (Typical when the t-stat has a green light.).
Please confirm
If a heat pump, is the outdoor unit frozen up? There can be some frosting, but it should not be a block of ice.
If there is an emergency heat switch on the t-stat, can you flip that to emergency heat? Do you get heat then?
Pleas advise and I can help you troubleshoot this problem further.
Jan 30, 2009 | Intertherm P3RA-060K Air Conditioner
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
