Question about Kaser Corporation Mambo Mano Digital Media Player
Video menu Does not appear
I have the player and have read the online pdf manual which said to press mode and navigate to the video menu, to view videos. I have synced amv, wmv, asf, mtv, mp4 files to the disk in a "Videos" folder. I wanted to access them but the video menu didn't not appear after I tried navigating to it.
Prees mode y dejalo presionado vizulizara the setup y pdras elegir la opcion deseada
Posted on Feb 21, 2008
I have bought a rca mp3 player m4804r-a i have lost the manuel and i dont even know how to use it.. can i get some directions on how to download music off the internet
With the unit connected to a Windows computer by a USB cable, you can transfer MP3s to the player by dragging them from a folder on Windows to your M4804's folder when the unit is plugged in. If the music isn't in the correct format, you can use the EasyRip software to convert the files. Depending on the current protocol, your MP3 player will act like a flash drive (MSC) and you can just open the disc. In this mode, make sure to use the safely remove hardware control before disconnecting the USB cord. If the unit is in MTP mode, you will need to open the player in Windows Explorer and then open the Internal Storage location to drag files to the unit.
To switch modes from the Home menu, press +, -, forward or reverse to navigate to Settings. Press Play, then again navigate to Protocol. Then press Play and you can toggle between the two modes. If you use ITunes or another service, you need to be in MTP mode. (Set this when the unit isn't connected to a computer.)
RCA Audio Video has the manual for the M4804R on their product site here: . Click on the Support/Manuals tab. The direct link to the manual is . The Downloads tab has firmware and the EasyRip software.
I hope this helps.
Oct 25, 2011 | Audio Players & Recorders
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
Aug 29, 2009 | Toshiba 27DF47 27" TV
Need a link for the DV-M5056BLK-VP manual
Turn the Mode switch to capture mode, make sure the video icon is against the red triangle.
Press the Power button for about 1 second to enter video mode, the icon will appear on the upper left corner of the screen
Press ok to start recording
Press ok to stop recording the video
Press Menu for other options
For Photos:
Power On
Turn the Mode switch to capture mode, make sure the capture icon is against the red traingle
Press the OK button to take pictures
Press Menu to enter main menu for options
Feb 28, 2009 | VuPoint DV-M5056-VP Digital Camera
Setup menu selected entered component under VIDEO
I was able to read a couple of words on the menu screen and with the help of them manual I was able to figure out how to navigate to the default button and was able to reset.
Nov 24, 2008 | Toshiba SD-3990 DVD Player
Need to turn OFF progressive scan on Sony DVD DVP-NS57P
With the remote: While in STOP mode, press the DISPLAY button. Use up/down buttons to select SETUP. Press Enter. Use up/down buttons to select CUSTOM.Press Enter. Use up/down buttons to select SCREEN SETUP. Press Enter. Use up/down buttons to select PROGRESSIVE. Press Enter. The manual is a bit indistinct after this, but I think the prompts will direct you. Just turn Progressive OFF.
Owner's Manual page 61, link
Nov 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
How to restore factory settings for Coby 755 DVD Player
Ok I'm going to walk you through this...
Turn the DVD player on... give it a second to load up
Now Press Setup.. now navigate down 5 times Press Enter
Navigate down once Press Enter... Or it might just be a Press enter I'm reading from the manual. Click here for the Manual
That is the way to get to the factory default button in the setup.. If your having trouble doing that try using the manual to see where to go to get back to the NTSC settings
May 03, 2008 | Coby DVD-755 System
Screen cut off on the bottom - WT-42313 Mits 42"
Make sure your remote is the official Mit remote, and that it is set for TV, usually the far left setting at the top of the remote.
These remotes control many different devices. Some will allow video to work without allowing audio to work.
TV will allow all to work.
Mr Bob
Jan 23, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. "setup" "down arrow"(selects audio/video) "enter" (selects audio/video menu) "down arrow" 4 times (selects scan mode) "right arrow" (selects scan menu) "up arrow" (selects interlace mode) "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Kaser Corporation Mambo Mano Digital Media Player Logo
50 people viewed this question
Top Kaser Corporation Audio Players & Recorders Experts
Are you a Kaser Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
