Question about Intel Motherboard
Run Time Error 32 AT 0040475D
I am getting a run time error on my computer from time to time. At times I am unable to surf the net, I can not click on the links if I am googling something. And my other problem is that When I go to start I can not start any of my programs, I have to go thru the c drive inorder to open something. Can anyone help??
  • 263 Answers
First time error means your internal batery is feilure you have change the batery for programs you have to set the programs acces default goto control panel , taskbar and start menu and select the way you want to use your start up programs
Posted on Dec 28, 2007
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
Damaged system files.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
I get a "Unable to
Have you installed all of the smart updates for the software. I believe that it is currently at update 8.3.1.
If you're not sure, make sure that your computer is connected to the internet, open the desktop icon that gets you to the folder that holds the components of 4D, double click on "Configure" and then select "Smart Update". The software will check what you have on your computer, connect to the Husqvarna Viking server and ask you to log in to your user account, then any update that you have not run will be in a list to download and installed.That is always the first step to solving a run-time environment error.Let me know if you have problems after installing all updates.
Sep 10, 2011 | Husqvarna Viking 1
I bought a fsx and fsx acceleration but i want to do the missions but i cant i click on go to breifing and it it freezes then says run time error or something like that i have all the computer requirments
A run-time error is a Visual Basic error. Check that you have the newest version installed. Once done this will cure it. You also need to make sure that you have .NET framework installed from Microsoft.
Jul 17, 2009 | Microsoft Flight Simulator X for Windows
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
When I try to Launch The Bible Collection Suite, I get an error screen "Run time error '339':Component 'sssplt30.ocx'or one of its dependencies not correctly registered: a file is missing or...
try to run the same ocx. by clicking it or right clicking and selecting a option from the menu .once u get to run it it would be registered.
Nov 27, 2008 | Computers & Internet
C++ run time error
Hi ,
Try loggin on to safe mode and check whether you get the same message ---
How to log on to safe mode - Keep tapping f8 While system boots and choose safe mode or safe mode with networking. --- If no error message do a clean boot.
How to do clean boot --
Click Start - Run - types msconfig - opens system configuration utitlity --- Click on services tab -- check the box hide all Microsoft services, then click disable all ***** click to the tab start and disable all click apply then close and it will prompt you to restart the computer . Restart the computer. I hope it fixes the issue .
Nov 15, 2008 | Microsoft Windows Vista Ultimate Edition
Error code 80048820
MSN Message error 80048820, unable to signin
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
- Correct the computer system's Time/Day as current (if required).
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
Aug 12, 2008 | Computers & Internet
While surf net error message run time error
update your computer through microsoft's webpage...
Jun 30, 2008 | Microsoft Windows XP Professional With...
Unable to Change System Tray "time and date"
Try scan your computer some potent anti virus, like kaspersky, or maybe avg is free.
if sure it virus free: then do this,
type' gpedit.msc' and enter
on user configuration
click; administrative and templates
and then. system
Ctrl+Alt+Delete option
at the right side window
double click "remove task manager"
check, Disabled box option.
then ok.
if same problem then some virus on it.
Dec 28, 2007 | Microsoft Windows XP Home Edition
RUN TIME ERROR 2147217842(80040e4e)
have u check the net framework version of the os ur using
Dec 18, 2007 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
