Question about Philips HDD070 MP3 Player
On screen message
Message on the screen says..Problem please connect to computer but when you do this you cant do anything. Please help format
  • Eric Cave Aug 04, 2008
    Problem please connect to computer but when i do this i cant do anything. Please help format and it need the softwear for the mp3 player but i have missplace my own please need me out....
format
Posted on Sep 10, 2008
  • juzar_c Sep 10, 2008
    I do not have the disc, disc as crashed.
  • 376 Answers
You need to download Phillips GoGear HDD from there website to reset the firmware. this program might be on the disc that came with the player.
Posted on Jan 22, 2008
  • L Jefferson
    L Jefferson Aug 14, 2008
    For the other problem- Go to the philips website and you'll be able to download the software from the Support section of the site.
Kodak c433 stuck in connect mode
You may have to connect to a computer then disconnect it from the computer safely(click on safe removal icon in the tray)?
Feb 15, 2012 | Kodak EasyShare C433 Digital Camera
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Can you tell he how to send a text, I cant see anything on screen
The normal procedure for sending a text message in your phone is as follows. If this does not work, please take it to the nearest service centre before anything searious happens. Also the following instruction needs you to have your message centre settings filled as got from the service provider.
Process:
Press Navigation key (Centre) -> Select 'Messaging' -> Select 'Create Message' -> Select 'New Short Message'
I hope this could help you understand your problem better.
Have a nice day
Bye
Nov 26, 2008 | Motorola Mobility RAZR V3
Sansa clip says i must free 4mb then switches off
You should format the device using windows media player or the device itself..that should fix the problem you are having..remember formatting will delete all the date you have on the device..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Sep 19, 2008 | SanDisk Sansa Clip MP3 Player
Iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
Aug 01, 2008 | iRiver X20 MP3 Player
Please connect to pc
Spoke to philips
after they tried without success
advised faulty machine
got replacement from supplier
thankyou for your help
Aaln
Jun 12, 2008 | Audio Players & Recorders
Not enough space for music db. please free 6mb
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=23609&query.id=137762#M23609
PLace the Sansa in Recovery Mode, plug in, and see that the 16MB FORMAT icon appears in Windows Explorer.
Right click in the window, and create a new folder named sansa.fmt
DO NOT ATTEMPT TO FORMAT THE RESERVED PARTITION USING THE WINDOWS FORMAT COMMAND!!
Drag and drop the sansa.fmt folder into the 16MB FORMAT partition. Right-click and select eject.
Unplug, and see if it will automatically format.
Thanks to neutron_bob
Jul 21, 2007 | SanDisk Sansa e260 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
On screen message
have you tried reseting it? Try different usb port.
Jun 12, 2006 | Philips HDD070 MP3 Player
Philips HDD070  MP3 Player Logo
203 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
