Question about D-Link DI 514 Wireless Router (DI-514)
Password not working
I'm trying to set-up wireless router and the admin/password is not working. I've tried going to the Microsoft page and using the 4 options there with no luck...
    Scholar:
  • 112 Answers
Do the following: on your computer open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank. once logged on the router you can make your configurations. BPCS
Posted on Dec 30, 2007
  • lasaaning Dec 03, 2011
    I lost my windows vista admin passwords few days ago. I solved the trouble with the help of windows password reset tool. It not only support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from:http://www.reset-windows-password.com
I need to set a password for my Linksys Wireless-G WRT54G Router, but the websited 192.168.0.1 to set the password isnt working. I need help ASAP. Thank-You
to access the router page for linksys, you need to type 192.168.1.1 on the address bar. username is " admin " password is " password " if it doesnt work, try "admin" for username and "admin" for password. then it would take you to the router page. and you can start configuring.
Sep 09, 2011 | Linksys Wireless-G WRT54G Router
Im using a smcwbr14t-g router how can i create a secure wifi connection.a wifi with password so others cant connect thru my network.pls help ty
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 16, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
Can't open setup page from Encore ENHWI-N3
The best way to open the setup page is to have a wired connection to the router. Once you plugin the router to both the modem and the computer, you want to reboot everything. After you've established a connection, open a browser window and go to 192.168.0.1. To login to the setup page, enter admin for user and admin for password. From there you can change your password and setup the secured wireless networking.
You should also be able to try this wirelessly, but you must be sure that you have selected the Encore network on your computer's wireless control panel.
Jun 20, 2011 | Encore ENHWIN3 Wireless Router
How can i reset the password to my wireless router (wr850G) I've held down the reset button for more then 30 sec on and off with no luck and when I try to log into the router through a wired connection...
Did you try unplugging it, holding the reset button for 30 seconds, then plugging it in (while holding the reset button), then (after I'd say like 5-10 seconds) letting go of the reset button? Also, if you're seeing a blank configuration page, it could be that the username/password combination is wrong. Try using username "admin" and password "password" "1234" "0000" "admin" and leaving the password blank. One of those combinations should work.
If none of those work, unfortunately, it might be that somehow the router got damaged or broken somehow. You can try some of the steps from the manual (located here) to get it to work again, but you might want to look into a new router.
Jun 16, 2011 | Arris WR850G Router (DHWR850G)
I want to change my password lynksys wrt150n.
Are you speaking about the wireless network password?
For this you will need to access the setup page of the router?
Connect the computer to the router with the Ethernet cable.
open the setup page of the router.
Go to wireless tab and change the wireless settings.
If you want to change the ' Router ' password then go to administration tab and change the router password.
Click Here for more information about the routers and network
Oct 19, 2010 | Linksys Wireless-N WRT150N Router
What is linksys wireless -g broadband router factory name and password
Factory user name as "admin" and password as "admin" or blank or "password"
If above user name and password doesnot work then you need to reset it .
Press RESET button for 10 seconds.
RESET button is in back side of router.
Dec 25, 2009 | Linksys Wireless-G WRT54G Router
Linksys router G - buddy forgot password I am at my brother-in-laws home for the week and they don't know the username and password for the linksys but they do have custom settings. How can I just reset...
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Jul 01, 2009 | Linksys Wireless-G WRT54GS Router...
Router
hello!
the default router password is admin, no username. if that didnot work, possible that the router password is change during initial set up. try your own personal password
wireless password is different from the router password. if you enable the router wireless security and you dont know what it is, you can access the router setup page and go to the wireless security tab to get your wireless password
Aug 13, 2008 | Linksys Wireless-G WRT54G Router
D-Link DI 514 Wireless Router (DI-514) Logo
115 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
