Question about E-Machines (308714) Motherboard
E machine won't turn on
While the e machine was in use, the tower turned off, but the monitor remained on. I thought the battery might have died, so I replaced it, but the computer still won't turn on. The power supply seems to be fine, but I haven't been able to get the current to run through it. Any suggestions.
  • HiBanks Jan 14, 2008
    emachine will not turn on , no fans,no lights, nothing!!
    How do I test the PSU? witch color wire should have what meter reading?
    I tested mine with a dc probe light tester like you would use to test you vehicle and I got a dimm glow on the purple wire and a bright glow on the green one all other wires had none.
    Sergeant:
  • 263 Answers
You have to be sure about power check outlets power and power supply with power supply tester you can get that on any computer store i get mines from fry'z electronics after you check that probably not have to do any other test to me is the power supply if any of the out lines from power supply is bad you can have that problem the out lines have 12v 5v 3.3v and 3v so check that
Posted on Dec 28, 2007
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
Tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | Computers & Internet
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Aug 25, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
Tower turns on but nothing else does! Not the monitor, keyboard
Inside the case there will be a small Silver battery its only flat and not that big But if that dies then pc is unable to store boot up date even if pc isnt plugged in
So Replace that battery Put side case back on the pc Then plug in and turn on, It should boot up without any bleeping. And once replaced them battery's last for ages .
Jun 27, 2010 | Velocity Micro Edge Gaming Desktop PC ...
Tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Mar 28, 2009 | E-Machines eMachines Desktop PC
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Monitor
Same thing is happening with my emchine as well. Mine is a T6412 series machine. I boought this machine a year and a half ago. Suddenly one morning the monitor started flickering. At first I thought may be some problem with the cables. I tried with different cables. Same problem. then I thought maybe my monitor has gone bad. So I went and bought a new Samsung monitor. Even with this new monitor the problem remained. So, I am assumng now that the problem is with my computer and not the monitor. Can someone please help. I do not usually come to this site. Can you please email me your solutions and help directly to amalandy@hotmail.com. Thank you so much for your help.
Jul 08, 2008 | E-Machines eMachines Monitor E15T4
My monitor will not turn on
disconnect the monitor cable from your computer tower
if you get a 4 colored box which says power on self test. it means its not the monitor then you have to get the video card or the systemboard.
Jun 09, 2008 | Dell P793 17" CRT Monitor
E-Machines (308714) Motherboard Logo
216 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
